11-13-2012 07:33 AM - edited 03-07-2019 10:01 AM
Has someone heard of NEXUS 7000 Octopus internal error in device 78 message. I got this on NEXUS 7000 logs:
Nov 12 22:05:14 smale-outside : 2012 Nov 12 21:05:14 BRST: %MODULE-2-MOD_DIAG_FAIL: Module 2 (serial: JAF1548AMKB) reported failure on ports 2/1-2/32 (Ethernet) due to Octopus internal error in device 78 (device error 0xc4e0025b)
Nov 12 22:05:17 smale-outside : 2012 Nov 12 21:05:17 BRST: %MODULE-2-MOD_FAIL: Initialization of module 2 (serial: JAF1548AMKB) failed
Nov 12 22:05:18 smale-outside : 2012 Nov 12 21:05:18 BRST: %MODULE-2-MOD_FAIL: Initialization of module 2 (serial: JAF1548AMKB) failed
and :
nx7000-wc0# sh module
Mod Ports Module-Type Model Status
1 32 10 Gbps Ethernet Module N7K-M132XP-12 ok
2 32 10 Gbps Ethernet Module N7K-M132XP-12 powered-dn
5 0 Supervisor module-1X N7K-SUP1 active *
10 48 10/100/1000 Mbps Ethernet Module N7K-M148GT-11 ok
Mod Power-Status Reason
2 powered-dn Reset (powered-down) because module does not boot
nx7000-wc0# sh version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2010, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
BIOS: version 3.22.0
kickstart: version 5.1(1)
system: version 5.1(1)
BIOS compile time: 02/20/10
kickstart image file is: bootflash:///n7000-s1-kickstart-npe.5.1.1.bin
kickstart compile time: 12/25/2020 12:00:00 [10/24/2010 08:25:25]
system image file is: bootflash:///n7000-s1-dk9-npe.5.1.1.bin
system compile time: 9/2/2010 19:00:00 [10/24/2010 09:34:48]
Hardware
cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor module-1X")
Intel(R) Xeon(R) CPU with 4109596 kB of memory.
Processor Board ID JAF1444BLKS
Device name: nx7000-wc0
bootflash: 2029608 kB
slot0: 0 kB (expansion flash)
Kernel uptime is 222 day(s), 4 hour(s), 9 minute(s), 22 second(s)
Last reset
Reason: Unknown
System version: 5.1(1)
Service:
plugin
Core Plugin, Ethernet Plugin
CMP (Module 5) ok
CMP Software
CMP BIOS version: 02.01.05
CMP Image version: 5.1(1) [build 5.0(0.66)]
CMP BIOS compile time: 8/ 4/2008 19:39:40
CMP Image compile time: 9/2/2010 19:00:00
nx7000-wc0#
I only have found:
http://www.cisco.com/web/software/datacenter/N7K/nxos_521_sw_advisory.html
which does not match reality : No one was configuring Vlans.
Solved! Go to Solution.
11-13-2012 09:27 AM
Hi Rosa,
You are having same problem, please try to reload the module 2 and check the performance.
Aru
*** Please rate if the post is useful ***
11-13-2012 08:17 AM
For Cisco Nexus 7000 series switches running NX-OS 5.2(1), M1-series modules can reset or link state across multiple ports can flap after configuring a new VLAN with SPAN. A full list of all M1-series modules is provided below:
N7K-M148GT-11=
N7K-M132XP-12=
N7K-M148GS-11=
N7K-M148GS-11L=
N7K-M108X2-12L=
N7K-M132XP-12L=
N7K-M148GT-11L=Please note that this is a software caveat (CSCtt43115) and not a hardware issue on the M1-series modules.
This issue only occurs on Cisco Nexus 7000 series switches running NX-OS 5.2(1) when a TX SPAN session is configured with the destination port as a trunk port. The SPAN destination port could be in either an M1 or F1 module.
The following error messages can be seen when the issue occurs:
%MODULE-2-MOD_DIAG_FAIL: Module X (serial: ) reported failure on ports X/1-X/48 (Ethernet) due to Octopus internal
error in device 78 (device error [ErrCode])
There are two methods to workaround this issue:
1) Remove all the monitor sessions, configure VLAN(s) and restore all monitor session configurations.
2) Configure the SPAN destination port as an access port instead of a trunk port.Either of the above options should be repeated every time a new VLAN needs to be configured.
This issue is applicable only to the NX-OS 5.2(1) release. This issue is NOT applicable to pre-5.2 releases or 5.2(3a) and later.
Additional Workaround Information:
If the affected Nexus 7000 module(s) are powered down after a few reloads, then follow the steps mentioned below to recover the modules (relevant CLI commands are provided):
1) Remove the newly added VLAN.
2) Remove the monitor session(s).N7K-CORE(config)#no monitor session 13) Manually reload the M1 module(s) from the default VDC.
N7K#reload module [mod#]4) Once the modules are up, add the new VLANs.
To follow the bug ID link below and see detailed bug information, you must be a registered customer and you must be logged in.
DDTS Description {CSCtt43115} (registered customers only) N7K/5.2(1) Adding a new vlan reloads M1-series linecards
Software
Hardware
11-13-2012 09:03 AM
Hi Rosa,
As you mentioned previously, this issue is applicable only to 5.2(1) release not in 5.1(1)
Octopus is one of the internal ASIC avialble on module N7K-M132XP-12. There are two Octopus ASICs are mapped to multiple interfaces.
1,3,5,7,9,11,13,15,17,19,21,23,25,27,29,31 - All even ports are mapped to Octopus 1
2,4,6,8,10,12,14,16,18,20,22,24,26,28,30,32 - All odd ports are mapped to Octopus 0
Our case, we are seeing problem on all the ports
Nexus7010# sh system error-id 0xc4e0025b
Error Description: Device Name:[Octopus] Instance:[0] Error Type:[hw error] code:[91]
Example:
Nexus#show module internal exceptionlog module 10
********* Exception info for module 10 ********
exception information --- exception instance 1 ----
Module Slot Number: 10
Device Id : 78
Device Name : Octopus
Device Errorcode : 0xc4e01266
Device ID : 78 (0x4e)
Device Instance : 01 (0x01)
Dev Type (HW/SW) : 02 (0x02)
ErrNum (devInfo) : 102 (0x66)
System Errorcode : 0x410b003a Octopus internal error
Error Type : Minor error
PhyPortLayer : Ethernet
Port(s) Affected : 31
Error Description : OC_DF_TX1_INT_TX_TIMER_EXP_INT
DSAP : 0 (0x0)
UUID : 0 (0x0)
Time : Mon Nov 1 08:21:47 2010
(Ticks: 4CCE789B jiffies)
Aru
11-13-2012 09:20 AM
nx7000-wc0# show module internal exceptionlog module 2
********* Exception info for module 2 ********
Module Slot Number: 2
Device Id : 78
Device Errorcode : 0xc4e00266
Device Instance : 00 (0x00)
Error Type : FATAL error
Port(s) Affected : 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32
DSAP : 0 (0x0)
UUID : 0 (0x0)
Time : Tue Nov 13 13:27:04 2012
(Ticks: 50A274D8 jiffies)
exception information --- exception instance 2 ----
Device Id : 78
DSAP : 0 (0x0)
UUID : 0 (0x0)
Time : Tue Nov 13 12:10:42 2012
(Ticks: 50A262F2 jiffies)
exception information --- exception instance 3 ----
Device Id : 78
DSAP : 0 (0x0)
UUID : 0 (0x0)
Time : Tue Nov 13 11:53:54 2012
(Ticks: 50A25F02 jiffies)
exception information --- exception instance 4 ----
Device Id : 78
Device Errorcode : 0xc4e0025b
ErrNum (devInfo) : 91 (0x5b)
Error Description : OC_DF_TX0_INT_TX_TIMER_EXP_INT
DSAP : 0 (0x0)
UUID : 0 (0x0)
Time : Tue Nov 13 11:14:59 2012
(Ticks: 50A255E3 jiffies)
exception information --- exception instance 5 ----
Device Id : 78
DSAP : 0 (0x0)
UUID : 0 (0x0)
Time : Mon Nov 12 21:05:14 2012
(Ticks: 50A18EBA jiffies)
exception information --- exception instance 6 ----
Device Id : 78
DSAP : 0 (0x0)
UUID : 0 (0x0)
Time : Sat Nov 10 03:40:36 2012
(Ticks: 509DF6E4 jiffies)
exception information --- exception instance 7 ----
Device Id : 78
DSAP : 0 (0x0)
UUID : 0 (0x0)
Time : Thu Nov 8 16:55:28 2012
(Ticks: 509C0E30 jiffies)
exception information --- exception instance 8 ----
Device Id : 96
Device Name : R2D2
Device Errorcode : 0x41830059
Device ID : 24 (0x18)
Device Instance : 48 (0x30)
Dev Type (HW/SW) : 00 (0x00)
ErrNum (devInfo) : 89 (0x59)
System Errorcode : 0x4183003d Loopback test failed. Packets lost on the LC at the MAC ASIC
Error Type : Warning
Port(s) Affected : 8
DSAP : 0 (0x0)
UUID : 0 (0x0)
Time : Tue Feb 14 18:51:50 2012
(Ticks: 4F3AD776 jiffies)
exception information --- exception instance 9 ----
Device Id : 123
Device Name : Platform
Device Errorcode : 0xc7b00227
Device ID : 123 (0x7b)
ErrNum (devInfo) : 39 (0x27)
System Errorcode : 0x40380027 LC/SUP powered down due to both ejectors popped open
PhyPortLayer :
Port(s) Affected :
DSAP : 39 (0x27)
UUID : 24 (0x18)
Time : Thu Oct 20 15:04:17 2011
(Ticks: 4EA05491 jiffies)
exception information --- exception instance 10 ----
Device Id : 70
Device Name : Santa-Cruz-Module
Device Errorcode : 0xc4600248
Device ID : 70 (0x46)
ErrNum (devInfo) : 72 (0x48)
System Errorcode : 0x40420009 X-bar Interface ASIC Error
PhyPortLayer :
Port(s) Affected :
DSAP : 0 (0x0)
UUID : 254 (0xfe)
exception information --- exception instance 11 ----
Device Id : 70
PhyPortLayer :
Port(s) Affected :
DSAP : 0 (0x0)
UUID : 254 (0xfe)
exception information --- exception instance 12 ----
Device Id : 70
PhyPortLayer :
Port(s) Affected :
DSAP : 0 (0x0)
UUID : 254 (0xfe)
exception information --- exception instance 13 ----
Device Id : 70
PhyPortLayer :
Port(s) Affected :
DSAP : 0 (0x0)
UUID : 254 (0xfe)
exception information --- exception instance 14 ----
Device Id : 70
PhyPortLayer :
Port(s) Affected :
DSAP : 0 (0x0)
UUID : 254 (0xfe)
exception information --- exception instance 15 ----
Device Id : 70
PhyPortLayer :
Port(s) Affected :
DSAP : 0 (0x0)
UUID : 254 (0xfe)
exception information --- exception instance 16 ----
Device Id : 123
Device Errorcode : 0xc7b02202
Device Instance : 02 (0x02)
ErrNum (devInfo) : 02 (0x02)
System Errorcode : 0x40380026 One ejector is open (Ejector instance=ErrNum)
PhyPortLayer :
Port(s) Affected :
DSAP : 39 (0x27)
UUID : 24 (0x18)
Time : Thu Oct 20 15:04:16 2011
(Ticks: 4EA05490 jiffies)
11-13-2012 09:27 AM
Hi Rosa,
Aru
11-13-2012 09:35 AM
In addition, I should tell you that:
1. there are 2 DELL 6224 :
Eth2/26 and
Eth2/30
2. when 10 Gbps Ethernet Module N7K-M132XP-12 powered-dn
6224 fibers where detached
3. I have executed:
conf t
no poweroff module 2
attach module 2
exit
4. I ahve attache 6224 to Eth2/26
5. The arrangement is running fine for more than an hour.
6. I will wait a little bit longer to attach Eth2/30
