Nexus 7000 output discards not matching policy-map drops.
jkeeffe
Level 2
Level 2
I have a QoS service policy applied to a 10gig interface on a Nexus 7000.  'Show int' of the interface shows 1067 output discards, but a 'show policy-map' of the interace shows no drops in any of the classes.  This seems to imply that output discards are occurring, and yet there is not congestion at the time to force output queues to drop packets as required by the QoS policy map. The outputs of both show commands are below. What could cause output discards in this case?
ROC-NX7010B-CORE-B# sh int e2/7
Ethernet2/7 is up
  Dedicated Interface
  Hardware: 10000 Ethernet, address: 64a0.e740.5542 (bia 70ca.9b40.90c2)
  Description: DU-D
  Internet Address is 164.72.187.110/30
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Auto-Negotiation is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 3d07h
  Last clearing of "show interface" counters 21:49:50
  30 seconds input rate 3095840 bits/sec, 825 packets/sec
  30 seconds output rate 9884928 bits/sec, 1888 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 3.59 Mbps, 968 pps; output rate 11.23 Mbps, 1.81 Kpps
  L3 in Switched:
    ucast: 0 pkts, 0 bytes - mcast: 0 pkts, 0 bytes
  L3 out Switched:
    ucast: 116744989 pkts, 63298925848 bytes - mcast: 0 pkts, 0 bytes
  RX
    100607249 unicast packets  33626 multicast packets  0 broadcast packets
    100640877 input packets  31998358300 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    117941510 unicast packets  28945 multicast packets  0 broadcast packets
    117970455 output packets  63555760528 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  1067 output discard
    0 Tx pause
  0 interface resets
ROC-NX7010B-CORE-B# sh policy-map int e2/7
Global statistics status :   enabled
Ethernet2/7
  Service-policy (queuing) input:   default-in-policy
    SNMP Policy Index:  301990105
    Class-map (queuing):   in-q1 (match-any)
      queue-limit percent 50
      bandwidth percent 80
      queue dropped pkts : 0
    Class-map (queuing):   in-q-default (match-any)
      bandwidth percent 20
  Service-policy (queuing) output:   10gig-OUT
    SNMP Policy Index:  301990657
    Class-map (queuing):   1p7q4t-out-pq1 (match-any)
      priority level 1
      queue-limit percent 15
    Class-map (queuing):   1p7q4t-out-q2 (match-any)
      queue-limit percent 25
      random-detect cos-based
      random-detect cos 7 minimum-threshold percent 95 maximum-threshold percent 100
      random-detect cos 6 minimum-threshold percent 90 maximum-threshold percent 95
      random-detect cos 3 minimum-threshold percent 85 maximum-threshold percent 90
      bandwidth remaining percent 22
    Class-map (queuing):   1p7q4t-out-q3 (match-any)
      random-detect cos 2 minimum-threshold percent 90 maximum-threshold percent 100
      bandwidth remaining percent 5
    Class-map (queuing):   1p7q4t-out-q-default (match-any)
      queue-limit percent 35
      random-detect cos 1 minimum-threshold percent 80 maximum-threshold percent 90
      random-detect cos 0 minimum-threshold percent 90 maximum-threshold percent 100
      bandwidth remaining percent 73
Please can yo help me, I have two QoS service policy applied to a 10gig interface on a Nexus 7000. 'show policy-map' of the interace shows 500858 output discards,
if you know any commands to see the specific ip match Qos policy. we need to see if some Ip´s to drop packets by the Qos policy map ?
