Encrypted Traffic Analyzer(ETA) feature dont work after switch upgrade
dima.ostapenko
After Catalyst C9500-24Y4C Switch upgrade from Gibraltar-16.12.4 to Bengaluru-17.6.3 this ETA commands don't available in configuration:
et-analytics
ip flow-export destination X.X.X.X 2055
vlan configuration XXX
ip flow monitor IPv4_NETFLOW input
et-analytics enable
Output of show platform software et-analytics global:
ET-Analytics Global state
All Interfaces : Off
IP Flow-record Destination : 0.0.0.0 : 0
Inactive timer : 0
Active timer : 0
ET-Analytics interfaces
No interface has ET-Analytics
ET-Analytics VLANs
How can I enable ETA feature in this release?
Thanks.
balaji.bandi
AFter upgrade i would check the License again :
i will also re-apply the config on 17.6.3
the flow desitnation show all 0.0.0.0
also is this SDA ?
Restrictions for Encrypted Traffic Analytics
  • ETA is supported only on access ports and wireless VLAN on SDA deployment. It is not supported on management, trunk, port-channel, SVI, and loopback interfaces.
  • ETA and transmit (Tx) Switched Port Analyzer (SPAN) is not supported on the same interface.
BB
No, it isn't SDA deployment.
Licenses is ok and the same as previouse version IOS-XE:
C9500 Network Advantage and C9500 24Y4C DNA Advantage
