Nexus 7000 series 18 slot switch os upgrade process running in VPC
prem.ce24
Hello Team,
Please send process/commands to upgrade os in nexus 7000 series  18 slot, 2 routing engin switch that running in VPC
regards
Prem Prakash
InayathUlla Sharieff
Prem,
Please find the procedure below:-
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/upgrade/guide/b_Cisco_Nexus_7000_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide_Release_6-x.html
Inayath
The following s procedure describes how to upgrade a device that has dual supervisor modules to the latest Cisco NX-OS software:
Step 1 Log in to the console port on both of the active and standby supervisor modules.
Step 2 Log in to Cisco.com and download the latest Cisco NX-OS kickstart and system images to a server.
Step 3 Download the Cisco NX-OS kickstart and system images from the server to your device using the copy command.
Step 4 Save the device configuration using the copy running-config startup-config vdc-all command.
Step 5 Enter the install all command at the active supervisor command prompt to upgrade the Cisco NX-OS software on your device..
