09-14-2016 09:03 AM - edited 03-08-2019 07:25 AM
This Cisco URL speaks to the Cisco Nexus 7010 Fabric modules have been marked EOL
Is this doc referring to the Nexus 7010 Chassis OR the Nexus 7010 Fabric modules or both?
Thanks to anyone that can clear it up!
Frank
09-14-2016 12:57 PM
Hi;
Till now Cisco don't announce EOS/EOL of Nexus 7000 Chassis. Please find the link below:
http://www.cisco.com/c/en/us/support/switches/nexus-7000-10-slot-switch/model.html
The link you share is taking about Chassis 46Gbps/Slot (/ means per slot) which is indicated about Fabric module and replacement part is Fabric module - 2 which will provice 110Gbps per slot.
Thanks & Best regards;
09-14-2016 01:08 PM
Thanks what I thought too but after looking at the recommended upgrade path, it seems the chassis is included in the upgrade path which made me think twice (or 3 times more).
Frank
09-14-2016 01:15 PM
Hi Frank;
Some time it's happen.
