Nexus 7K 6.1 code and F2 series module how to enable priority queue for IPT
aacole
Level 5
Level 5
I have a 7K running 6.1 code, on F series line cards. I  need to set it to prioritise DSCP EF marked traffic, that's all at this stage, but am  unclear on the configuration steps required. The packets will already be  marked, I just need to ensure they end up in a priority queue.
Anyone done this who can point me at an example configuration, I need a starting point.
krun_shah
Here is cofiguration guide for qos
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/qos/configuration/guide/queuing.html#wp1101680
Thanks for the reply, I had already had a look through that manual, and made a start, but it didnt work. Now back at site, taken another look at this and come up with the following:
qos copy policy type queuing default-4q-8e-out-policy prefix 20G-EGRESS-
sh policy-map type queuing 20G-EGRESS-4q-8e-out
! Enter policy config mode:
! show the default queuing policy map created:
  Type queuing policy-maps
    class type queuing 1p3q1t-8e-out-pq1
      priority level 1
    class type queuing 1p3q1t-8e-out-q2
      bandwidth remaining percent 33
    class type queuing 1p3q1t-8e-out-q3
    class type queuing 1p3q1t-8e-out-q-default
! Apply to an interface:
int po3
service-policy type queuing output 20G-EGRESS-4q-8e-out
sh run int po3
!Command: show running-config interface port-channel3
!Time: Tue Jul 10 16:07:55 2012
version 6.0(3)
  description *** VPC Uplink to SeminarA ***
  switchport
  switchport mode trunk
  switchport trunk native vlan 499
  switchport trunk allowed vlan 300-302,310-314,320-323,350,353
  switchport trunk allowed vlan add 400,499,999
  vpc 3
! To show the cos to queue mapppings, check one of the port channel physical
members:
sh queuing interface e3/3
Egress Queuing for Ethernet3/3 [Interface]
Template: 4Q8E
Que# Group Bandwidth% PrioLevel Shape%     CoSMap
   0     0          -      High      -        5-7
   1     1         33         -      -        3-4
   2     2         33         -      -        1-2
   3     3         33         -      -          0
Ingress Queuing for Ethernet3/3 [System]
Trust: Trusted
Que# Group Qlimit% IVL      CoSMap
   0     1      90   0         0-4
   1     0      10   5         5-7
Yet to test fully, but I think this will do the job. Only issue is that I have to use CoS as opposed to DSCP for the queues, but the IPT traffic should already have the correct CoS value set in the inbound traffic.
Final config:
int po3
