Nexus 7K BGP under a VRF
Bharat Negi
I have nexus 7010 with 6.2(14) version.  It is configured with BGP and VRFs like below
router bgp 1
vrf VRF_A
neighbor 2.2.2.1 remote-as 2
neighbor 2.2.2.2 remote-as 2
neighbor 2.2.2.3 remote-as 2
vrf VRF_B
neighbor 3.3.3.1 remote-as 3
neighbor 3.3.3.2 remote-as 3
neighbor 3.3.3.3 remote-as 3
When I shutdown BGP for specific neighbor under specific VRF it works well.
R1(config-router)# vrf VRF_A
R1(config-router-vrf)#neighbor 2.2.2.1 remote-as 2
R1(config-router-vrf)#shutdown
But when I issue a "shutdown" command under a particular VRF, it shuts down all the peerings under VRF_A (which is quite expected) but as well under VRF_B as well (which is not expected).
Has somebody encountered this issue?  Or can you test this in the lab and share results. Just wondering if I am doing something wrong or there is some bug in the code.  Thanks.
Bharat
Bharat Negi
Just found this on bug on Cisco website - https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz01405
This is NXOS BGP enhancement to change the behaviour when 'showdown' command is entered under BGP VRF.
The current design allows shutdown the entire BGP process when the command 'shutdown' was accidently entered under BGP VRF even though 'showdown' is not supported command under BGP VRF.
Some customer intentionally or accidently could type 'shutdown' under BGP VRF in their network operation and implementation.
When entering 'shotdown' under VRF, as this command is not found (not supported) in the current VRF mode, it's automatically finding matching command in router BGP then it executes 'showdown' which results BGP service outage/network down.
The same behaviour is not found from IOS but NXOS.
Bharat
Bharat Negi
Bharat
