Nexus 7K Directed Broadcast
alanjbrown
It is recommended good practice to disable ip directed-broadcast. I have a couple of vlans however which may require to use the WoL (Wake on LAN) feature. I decided that I would add the access-list to the ip directed-broadcast as detailed here:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/unicast/command/reference/l3_cmds_i.html#wp1611073
It says the command has been available since 4.0(1) however the parameter doesn't seem to be available in version 5.1.5.
MYN7KCR02(config)# int vlan 240
MYN7KCR02(config-if)# ip directed-broadcast ?
  <CR>
Is there another way of removing the directed-broadcast but still allowing WoL? Is this avaialble in another version of NX-OS?
thks,
Al
Reza Sharifi
The ACL keyword name is defiantly available in 6.1.1
have a look:
c7010-(config-if)# ip directed-broadcast ?
  WORD   ACL policy name (Max Size 63)
