10-04-2010 09:29 AM - edited 03-06-2019 01:18 PM
hi Experts,
I'm trying to configured egress traffic shaping at average of 100Mbps on a 1Gbps physical L2 trunk port.
I'm running on Nexus 7K version 5.0(2a) and the line card support 1p3q4t
I've looked at the 'policy-map type queuing' which has a shape command in the
'class type queuing 1p3q4t-out-q-default' but i couldn't figure out how i can shape
all 4 queues to achieve an average egress rate of 100Mbps for all traffics.
Does Nexus 7K support egress traffic shaping?
I also notice that Nexus 5548P doesn't support traffic shaping
K.H.See
10-23-2010 11:57 PM
Thanks Jeye,
Let me say that instead having a dedicated box for Core, I can do a VDC-core/VDC-agg model on the same chassis with 2 Redundant Cisco Nexus 7010. My only concern now is to connect the Backup site for my Data Center; Is it possible to get L2 or L3 with 40Gb optical link connected directly to the Nexus VDC core or I have to forward the trafic via the MPLS Backbone (via 7600 PE)?
10-24-2010 09:22 AM
When you said 40GB optical link, do you mean 40GB portchannel or 40GB port? If you mean 40GB port/interface, it is not possible as of now, there isn't any line card in the N7K supports this. If your provider will get you 40GB portchannel, I don't see any reason why you can't do this if the N7K has all the features that you need. Is this a good idea, this will be a different story.
jerry
