Nexus 7k Interface Configuration
angel-moon
Level 7
Level 7
All,
I know how to get into the VDC that I need to work on to issue a "No shut" command but when I try to go into the Interface I get an error message.  It won't take "Interface Ethernet1/24"  seems like it is saying gthere sdhould be something after the 24 but I canpt figure out what.  A lil help please?
Thanks.
replies rated
6 Replies 6
Rajeshkumar Gatti
Can you share the "sh vdc membership" command output from the admin/default VDC?
Also please share
show module
show vdc.
Also can you print the session log that shows this problem.
-Raj
Looking at your ouputs, are you logging into the VDC  using below-
conf t
vdc <vdcname>
If so then that is only for configuring the vdc and allocating resources to it. Make sure you allocate interface e1/24 (plus other interfaces that you need) to the vdc using below command -
conf t
vdc <vdcname>
allocate interface Ethernet1/24
Then you can switch to the vdc using "switchto vdc <vdcname>". This actually takes you to the vdc and allows you to configure the interfaces and other features specific to that VDC.
Hope this is clear.
-Raj
Ganesh Hariharan
Is that interface is part of VDC , what you see after logging onto VDC by issuing command show interfaces ?
-GI
If I go into the VDC I get tihs output
CORE(config-vdc)# show interface
mgmt0 is up
  Hardware: GigabitEthernet, address: xxxx.xxxx.xxxx.xxxx (bia xxxx.xxxx.xxxx.xxxx)
  Internet Address is 10.0.0.1/123
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  full-duplex, 1000 Mb/s
  Auto-Negotiation is turned on
  EtherType is 0x0000
  Rx
    34376347 input packets 3257180654 bytes
23191680 unicast packets 424571 multicast packets
    10760096 broadcast packets  1 packets/sec
  1 minute input rate 1432 bits/sec,  Tx
    23200722 output packets 4885265816 bytes
23183986 unicast packets 0 multicast packets
    16736 broadcast packets  1 packets/sec
  1 minute output rate 2832 bits/sec,
same output when done in config mode and error if tried at #
As i suspect, The interface is not allocated to CORE VDC.
So as per suggestion by Raj do the allocation of interface as per below commands.
conf t
vdc <vdcname>
Once done then you can see the interface under CORE VDC.
Hope it Helps..
-GI
Rate if it Helps.
glen.grant
  It looks like you are global config mode . You need to get into the VDC itself .   From there use  the switchto command .   switchto vdc <vdcname>  .
