12-29-2016 08:02 PM - edited 03-08-2019 08:44 AM
Hello, Can i use supervisor 1 with f2 card? Right now i am using M1 with supervisor 1.
Planning to replace M1 with F2, is there any problem with this when using Supervisor engine 1?
Thank you.
Solved! Go to Solution.
12-30-2016 02:36 PM
Have a look at this link. Sup 1 supports F2 cards but not F3.
http://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/nexus7000/sw/matrix/technical/reference/Module_Comparison_Matrix.pdf
12-30-2016 02:36 PM
12-30-2016 02:39 PM
Great Chart. Thank you!
12-30-2016 03:09 PM
Glad to help.
Thanks for the rating!
