Nexus 7K syslog message: %DAEMON-2-SYSTEM_MSG: fatal: no hostkey alg - sshd
Radovan Djogo
Hi everybody!
Did anyone encounter this error on Nexus 7K
It's also the last syslog message on the box for the last 5 days, while the other box has plenty of log messages for the same period, as usual.
Can't seem to find anything on this in documentation.
ashirkar
Level 7
Level 7
Hello Radovan,
Please refer this document for your query
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_0/nx-os/release/notes/401_nx-os_release_note.html
Ashish
Community Manager-NI
Ashish,
Thanks, I've already looked into that document and didn't find anything really helpful.
Update: Logging is working on the box, it seems that it just so happened that there were no events to log for the last couple of days.
I've got the same thing on one of my 5k's, and it also has not produced any logs after it happened, while my other 5k has.
%DAEMON-2-SYSTEM_MSG: fatal: Write failed: Broken pipe .Client is 1.1.1.1 ,length of packet causing error 116 116  - sshd[19877]
1.1.1.1 is prime infrastructure
InayathUlla Sharieff
Hi Radovan,
This message means that some specific SSH client is trying to connect with
the Nexus device however there is any kind of script that is not compatible
and it is causing those error messages.
or in other way of saying-
A script running on your nms server  can trigger a ssh session to the nexus
boxes. Some kind of algorithm from the server sent to the nexus box generating these
messages.
"The message seem to have been harmless."
Also check the following bugs.
CSCta57645 &
CSCsu87911
Please  let me know if you have any questions.
REgards
Inayath
Plz rate all usefull posts.
