Nexus 9000 VLANs suspended when primary forms adjacency
Simon2000
I have a pair of Nexus 9000 switches configured with a vpc peer link using eth1/53 and eth1/54 (configured as port channel 128)
I have two Window hosts connected using LACP VPCs across the two switches, with a continual ping going from host 1 to host 2
If I reload the switch acting as the vpc primary then the ping traffic continues and the switch acting as the vpc secondary becomes the operational primary.
However when the switch that was acting as vpc primary starts forming the adjacency again then I see pings being dropped for 8-10 seconds.
In the log on the acting primary I see the following:-
%ETHPORT-5-SPEED: Interface Ethernet1/53, operational speed changed to 100 Gbps
%ETHPORT-5-IF_DUPLEX: Interface Ethernet1/53, operational duplex mode changed to Full
%ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/53, operational Receive Flow Control state changed to off
%ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/53, operational Transmit Flow Control state changed to off
%ETHPORT-5-SPEED: Interface port-channel128, operational speed changed to 100 Gbps
%ETHPORT-5-IF_DUPLEX: Interface port-channel128, operational duplex mode changed to Full
%ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel128, operational Receive Flow Control state changed to off
%ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel128, operational Transmit Flow Control state changed to off
%ETHPORT-5-SPEED: Interface Ethernet1/54, operational speed changed to 100 Gbps
%ETHPORT-5-IF_DUPLEX: Interface Ethernet1/54, operational duplex mode changed to Full
%ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/54, operational Receive Flow Control state changed to off
%ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/54, operational Transmit Flow Control state changed to off
%ETH_PORT_CHANNEL-5-PORT_UP: port-channel128: Ethernet1/53 is up
%ETH_PORT_CHANNEL-5-PORT_UP: port-channel128: Ethernet1/54 is up
%ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel128: first operational port changed from none to Ethernet1/53
%ETHPORT-5-IF_BANDWIDTH_CHANGE: Interface port-channel128,bandwidth changed to 100000000 Kbit
%ETHPORT-5-IF_UP: Interface Ethernet1/53 is up in mode trunk
%ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 31,35,40-42
%ETHPORT-5-IF_UP: Interface port-channel128 is up in mode trunk
%ETHPORT-5-IF_BANDWIDTH_CHANGE: Interface port-channel128,bandwidth changed to 200000000 Kbit
%ETHPORT-5-IF_UP: Interface Ethernet1/54 is up in mode trunk
%ETHPORT-3-IF_ERROR_VLANS_REMOVED:VLANs 31,35,40-42
The dropped pings start at the "IF_ERROR_VLANS_SUSPENDED" message and resume at the "IF_ERROR_VLANS_REMOVED" message
Is this expected behaviour? It is as if the peer link config between the two switches is mismatched until Ethernet1/54 is trunking.
19 Replies 19
Show vpc breif
Show etherchannel summary
Share this when issue appear
MHM
As requested:-
Switch1# show vpc brief
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 14
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 4
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled, timer is off.(timeout = 240s)
Delay-restore status : Timer is off.(timeout = 60s)
Delay-restore SVI status : Timer is off.(timeout = 20s)
Operational Layer3 Peer-router : Disabled
Virtual-peerlink mode : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po128 up 31,35,40-42,
vPC status
Id Port Status Consistency Reason Active vlans
1 Po1 up success success 40-42
2 Po2 up success success 40-42
3 Po3 down* success success -
50 Po120 down* success success -
Please check "show vpc consistency-parameters vpc <vpc-num>" for the
consistency reason of down vpc and for type-2 consistency reasons for
any vpc.
Switch1# show port-channel summary
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
b - BFD Session Wait
S - Switched R - Routed
U - Up (port-channel)
p - Up in delay-lacp mode (member)
M - Not in use. Min-links not met
Group Port- Type Protocol Member Ports
Channel
1 Po1(SU) Eth LACP Eth1/1(P)
2 Po2(SU) Eth LACP Eth1/2(P)
3 Po3(SD) Eth LACP Eth1/3(D)
120 Po120(SD) Eth LACP Eth1/45(D) Eth1/46(D) Eth1/47(D)
Eth1/48(D)
128 Po128(SU) Eth LACP Eth1/53(P) Eth1/54(P)
Which PO have issue ?
MHM
Apologies, this is the output from the two commands during the issue:-
Legend:
vPC domain id : 14
vPC role : primary, operational secondary
Delay-restore SVI status : Timer is on.(timeout = 20s, 13s left)
Channel
1 Po1(SD) Eth LACP Eth1/1(D)
2 Po2(SD) Eth LACP Eth1/2(D)
Eth1/48(D)
Switch2# show vpc brief
Legend:
vPC domain id : 14
vPC role : secondary, operational primary
Delay-restore SVI status : Timer is on.(timeout = 20s, 12s left)
Switch2# show port-channel summ
Channel
Eth1/48(D)
All port channels are affected. The test ping is between port channel 1 and port channel 2 but is the same for all port channels
Are you use dedicated l3 interface for keepalive or you use svi of  vlan over peer link trunk?
1-I think you miss add PO in show vpc brief
can you check it appear or not ?
2- I ask if you config keep alive as dedicate or with peer link
3- can I see show spanning tree
4- show lacp counter
5- show lacp neighbor
are you sure windows support LACP, I think you need to change Mode to ON
but let check this first
MHM
1. Here is the full show vpc brief
Legend:
vPC domain id : 14
Delay-restore SVI status : Timer is on.(timeout = 20s, 17s left)
vPC status
1 Po1 up success success 40-42,46-48
2 Po2 up success success 40-42,46-48
any vpc.
2. The keep alive is running over the MGMT interfaces. Currently its a direct connect as its in test but I have tested using an Ethernet switch with the same results.
3. Output from show spanning tree
Switch2# show span
VLAN0031
Spanning tree enabled protocol rstp
Root ID Priority 32799
Address 003a.9c4b.54a7
Cost 1
Port 4223 (port-channel128)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32799 (priority 32768 sys-id-ext 31)
Address 003a.9c4d.f7a7
Interface Role Sts Cost Prio.Nbr Type
Po128 Root FWD 1 128.4223 (vPC peer-link) Network P2p
VLAN0035
Root ID Priority 32803
Cost 1
Bridge ID Priority 32803 (priority 32768 sys-id-ext 35)
VLAN0040
Root ID Priority 32808
Cost 1
Bridge ID Priority 32808 (priority 32768 sys-id-ext 40)
Po1 Desg LRN 1 128.4096 (vPC) P2p
Po2 Desg LRN 1 128.4097 (vPC) P2p
VLAN0041
Root ID Priority 32809
Cost 1
Bridge ID Priority 32809 (priority 32768 sys-id-ext 41)
VLAN0042
Root ID Priority 32810
Cost 1
Bridge ID Priority 32810 (priority 32768 sys-id-ext 42)
VLAN0046
Root ID Priority 32814
Cost 1
Bridge ID Priority 32814 (priority 32768 sys-id-ext 46)
VLAN0047
Root ID Priority 32815
Cost 1
Bridge ID Priority 32815 (priority 32768 sys-id-ext 47)
VLAN0048
Root ID Priority 32816
Cost 1
Bridge ID Priority 32816 (priority 32768 sys-id-ext 48)
4 Show lacp counter
Switch2# show lacp counters
NOTE: Clear lacp counters to get accurate statistics
LACPDUs Markers/Resp LACPDUs
Port Sent Recv Recv Sent Pkts Err
port-channel1
Ethernet1/1 1259 53 0 0 0
port-channel2
Ethernet1/2 1328 55 0 0 0
port-channel128
Ethernet1/53 60 57 0 0 0
Ethernet1/54 57 57 0 0 0
5 show lacp neighbor
Switch2# show lacp nei
Flags: S - Device is sending Slow LACPDUs F - Device is sending Fast LACPDUs
A - Device is in Active mode P - Device is in Passive mode
port-channel1 neighbors
Partner's information
Partner Partner Partner
Port System ID Port Number Age Flags
Eth1/1 0,0-90-fa-96-47-5e 0x2 2982 FA
LACP Partner Partner Partner
Port Priority Oper Key Port State
0 0x0 0x3f
Po2 neighbors
Eth1/2 0,0-90-fa-c8-6-1e 0x2 2981 FA
0 0x0 0x3f
Po128 neighbors
Eth1/53 32768,0-3a-9c-4b-54-a7 0x1d1 183 SA
32768 0x7f 0x3d
Eth1/54 32768,0-3a-9c-4b-54-a7 0x1d5 183 SA
32768 0x7f 0x3d
Get it'
Vlan 46-48 is not allow in peer link trunk
So it break vpc
Why you not include it?
MHM
Apologies they are allowed but got removed when I scraped the output.
Switch2# sho vpc brief
Legend:
vPC domain id : 14
1 Po128 up 31,35,40-42,46-48
vPC status
any vpc.
Hi Friend
sorry I make you waiting but I run lab to follow with you step need for troubleshooting
when issue appear in both nexus share (if you can add it to text file it more easy)
switch# show vpc consistency-parameters vpc 1/2/3/120/128 <<- one by one
switch# show vpc consistency-parameters global
switch# show vpc consistency-parameters vlans
waiting your replay
Thanks alot
MHM
Apologies for the delay.
I've run the commands during the issue and attached the results from the two switches
thanks for more detail
the two doc. you share second one is good the first one the table is not past correctly
the show vpc consi vpc 1/2 dont show any thing from the peer only from local
are you sure you run PO with vpc 1 and 2 in both NSK
MHM
also
show vpc role <<- in both NSK not work as primary
MHM
I think this is because the reloaded switch is still forming a proper adjacency. If I run the command now on the reloaded switch it looks fine.
