Nexus 9236c - need factory reset assistance
Corri S
Hello, I have a dozen of these switches to factory reset. They are security locked and have previous customer configs, vlans, ports configured etc. How can I reset these switches so they are completely bare, just like day one out of the box?
6 Replies 6
Reza Sharifi
Not sure if there is a reset button, but if you have access to the switches, you may want to issue "write erase" and then reboot.
I have done this, then saved with copy run start, reloaded - for some reason there is vlan data that remains after reboot. I think it's the vlan recovery feature but unsure. I also tried secure erase and factory-reset all but the commands were not recognized. Tried both privileged exec and conf t. At the moment permanently removing the vlan data is I am stuck on. Thanks
Corri S
Unsure if this is relevant but when you load the nxos from loader prompt, it shows that it's security locked.
Does the OS you are running support this command?
factory-reset all
I don't believe so, Reza; I did end up clearing the drive with
switch(boot)# clear nvram
switch(boot)# init system
 Ended up wiping everything, even NXOS so I'm calling this progress (lol) Next step is to reload and confirm.
Thank you for your helpful input.
I learned that the two previous commands, although solving a problem it made a new one; there was no longer an nxos. I knew this because the PuTTY session would only show loader > and only 'lost+found' was rendering from 'dir' command; no .bin to be found.
I added nxos...bin to a thumb drive, connected it to usb port on back of switch, booted from the drive with
loader>boot usb1:nxos.<#>.bin after the set up process I was able to copy the nxos from usb to bootflash
switch# copy usb1:nxos.9.<#>.bin bootflash:
