Nexus 9396px switch w/ M12PQ module breakout ports
satish.txt1
Level 3
Level 3
I have Nexus 9396PX switch with M12PQ (12x40GE) ports and i want to break those ports in 10GE but i didn't see any document where it say Cisco 9396PX support QSFP breakout.
I have following config on N3K which breaked 40GE QSFP in 4x10GE ports,  Does N9396px support that?
hardware profile portmode 64x10G
Andrea Testino
Satish,
Unfortunately breakout is not supported on the 9396PX as well as the M12PQ module which is why the CLI isn't available.
Example on my 9396PX with an M12PQ:
9396-VTEP-A-vPC# show module
Mod Ports             Module-Type                       Model          Status
1    48   1/10G SFP+ Ethernet Module            N9K-C9396PX           active *
2    12   40G Ethernet Expansion Module         N9K-M12PQ             ok
Mod  Sw                Hw     Slot
1    7.0(3)I4(7)       1.0    NA
2    NA                1.1    GEM
9396-VTEP-A-vPC# show int e1/1 capabilities | i i breakout
  Breakout capable:      no
9396-VTEP-A-vPC# show int e2/1 capabilities | i i breakout
This is the case for all interfaces.
Hope that helps!
- Andrea
- Andrea, CCIE #56739 R&S
6 Replies 6
Reza Sharifi
The command is different on the 9k.
Here it is link and the command
link:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_010....
switch# configure terminal
switch(config)# interface breakout module 1
Module will be reloaded. Are you sure you want to continue(yes/no)? yes
it don't have that command :(    after interface (?) i am not seeing any "breakout" command
What are the options when you do
config t
interface ?
I am not in office but i can get you on monday,
when i did
conf t
interface ?
there were only 4 option but not breakout one, also i google and and tired everything but didn't get any answer,
if anyone here from Cisco can answer whether this hardware support or not.
Andrea Testino
Satish,
Mod  Sw                Hw     Slot
2    NA                1.1    GEM
Hope that helps!
- Andrea
Why are you so awesome :)  Thanks you so your reply!
