Nexus 9504 vPC module
hgm4217
Frequent Visitor
Frequent Visitor
Nexus9504 ver is 7.0(3)I4(6)
Traditionally, X9536PQ module 1 and 2 are used
Module 1 and 2 ports, module 2 ports, vPC peer-link was being used
Module 1 is X9536PQ and module 2 is X9636PQ due to module replacement
Peer-link is not 160G after X9636PQ replacement. (Module 1 80G only)
Is it because the modules are different?
Does it matter if the X9636PQ H/W ver is different?
pieterh
Note
You must ensure that all interfaces in the vPC have the identical operational and configuration parameters listed in this section.
Note
Enter the show vpc consistency-parameters command to display the configured values on all interfaces in the vPC. The displayed configurations are only those configurations that would limit the vPC Peer-Link and vPC from coming up.
hgm4217
Frequent Visitor
Frequent Visitor
The configurations displayed are the same.
Previously, module 1 (X9536PQ) 40g × 2 ports module 2 (X9536PQ) 40g × 2 ports port-channel 3 use a total of 160g.
but
Changed configuration Module 1 (X9536PQ) 40g*2 ports Module 2 (X9636PQ) 40g*2 ports do not have port-channel 3 commands entered in Module 2 at .
in the end
The peer-link became 80g from 160g because the command was not entered at all.
