Nexus 9508 physical maintenance
Electronic20
Hi Community:
How can I perform physical maintenance on the Nexus 9508?
Will there be a manual or procedure?
How to properly shut down the Nexus 9508?
The nexus 9508 is a 13 RU modular device, and has these modules inserted:
• 04 AC power supplies of 3KW
• 2 line cards 48p 1/10GBaseT and 4p 40/100G
• 1 line cards 48p 10G/25G and 4p 40/100G
• 02 supervisors
• 03 redundant fan modules
Your kind support
marce1000
  - What do you mean by physical maintenance ?
          What do you want to do ?
 M.
Hi @marce1000
It is external and internal cleaning of the Nexus.
Another point, what will be the correct procedure for turning off the Nexus?
regards
Electonic20
  - There is no special power off procedure  ; but make sure you save the (current) running configuration to the startup configuration first , then use the power on/off button , and if there is none, then pull the power cables out of the nexus
 M.
