Nexus Core replacement
ty.masse
Beginner
Beginner
We currently have a network with dual 6509 core switches Non E that we're looking at replacing in September so we can be better positioned for the future.  I'm seriously looking at proposing a single Nexus 7K with dual sups VS Two Nexus 7K with dual sups.  Am I crazy for wanting to go from dual 65k switches to a single Nexus core switch?  So far I can't think of a downside.
Let me know Pros and cons.
thanks.
Joseph W. Doherty
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
"Crazy", perhaps not, but the 6500 series isn't exactly defunct either.  You might want to look carefully at what you have now, and what the sup2t and follow-on road-map provides and then determine whether you need to jump to the Nexus 7K.
I love the 65K.  But since the core has to be replaced, I want to position us for the future.  Clearly the Nexus line is
where Cisco is heading.
The only two downsides I can think of with Nexus are: No POE support and no application Modules are supported.
I do love the VDC feature though.
I'm still on the fence.
As Joseph has mentioned above, the Catalyst 6500 platform is still on road maps and just had a whole bunch of new hardware released, e.g. Sup-2T and line cards. Whilst it is no secret that the Nexus platform is what Cisco are selling people to go down the unified comms journey, the 6500 platform still has it's place within the data centre, especially as a services platform.
A recent (within last 12 months) example I can give you - I picked the 6500 platform for a large data centre network over the Nexus to provide 10GbE connectivity to huge amounts of server chassis with extremely high virtualisation ratios. Why? Because for this particular environment the Nexus platform couldn't meet all the business requirements, the 6500 could. Moral of the story? Use whatever product meets your business and technical requirements. There's no point asking a public forum "should I or shouldn't I" around any technology when you have provided no background information around those requirements.
Yes the Nexus platform has shiny features such as VDC, it also has some pretty big caveats depending on what you are doing - once again, back to what are your business and technical requirements?
As far as being crazy for considering a single N7k with dual sup's versus dual N7k's, it's no more crazy than not providing chassis redundancy using any other product. If you believe a single chassis can deliver to your business, technical AND availability requirements then sure, go for it.
Thanks to all that have commented.  I'll certainly draw from your feedbacks as part of the mix when it comed decision time.
Recognize Your Peers
