Nexus default configuration
opnineopnine
Hi all,
I have my Nexus 5000 and 7000 and I would like to know if I can have configurations that will affect all interface by default, example: for eigrp all interfaces are in "passive interface"
thanks.
Reza Sharifi
Not sure if I understand the question, but yes, If you add that command to EIGRP than that puts all interfaces in passive mode. And in this case if you want one interface to be active you just add "no passive interface ex/x"
What I want to do is to have a default cofiguration for all interfaces.
Thanks.
