Nexus - Device Redundancy Status not OK
abc1235
pieterh
your description of the situation is very cryptic I can only guess what you mean
"second redundant Nexus Switch" => what do you mean by this,
is it a second switch or is it a third switch added to an already redundant configuration ?
what configuration did you apply with the intent to make it redundant ?
" In the monitoring tool, I get an alert that the Device Redundancy Status is not OK" => what monitoring tool ?
can you share the exact log message
Thanks A Lot
MHM
