Nexus eigrp vrf -- route redistribution
danilo-dicesare
Hi all,
i'm having some problem in redistributing static route in eigrp with vrf configured.
i'll show you configuration:
Device A
version 5.1(1a)
feature eigrp
router eigrp 667
  autonomous-system 667
  vrf BB_backend
  address-family ipv4 unicast
    redistribute static route-map rmall
interface Vlan101
  ip router eigrp 667
interface Ethernet2/3.100
  ip router eigrp 667
show ip eigrp nei vrf BB_backend
IP-EIGRP neighbors for process 667 VRF BB_backend
H   Address                 Interface       Hold  Uptime  SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
1   192.168.1.13            Vlan101         11   02:38:28  1    200   0   20
0   192.168.1.5             Eth2/3.100      11   02:39:59  332  1992  0   17
IP access list all
        10 permit ip any any
route-map rmall, permit, sequence 10
  Match clauses:
    ip address (access-lists): all
  Set clauses:
vrf context BB_backend
  ip route 172.16.0.112/29 192.168.1.22 name DMZ
DeviceB (nexus)
show ip eigrp neighbors vrf BB_backend
                                            (sec)         (ms)       Cnt Num
1   192.168.1.14            Vlan101         14   00:00:22  1    200   0   24
0   192.168.1.10            Eth2/3.100      14   00:00:22  1    200   0   32
ive tried with and without address-family configured but behaviour is the same.
any hints?
tnx
dan
Jerry Ye
Based on your command output in your post, I can't tell what is wrong. Can you post the route-map configuration along with the static route config. Also, show ip eigrp neighbor will not tell me does the static route redistributed into the eigrp table or not. What you need to post is the eigrp topology table output of the static route prefix
show ip eigrp topology x.x.x.x/x
jerry
