Nexus ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet is down
open24hrs
I have a Nexus 9K trunked to a C9200L
On the Nexus 9K the port is:
interface Ethernet1/19
switchport
switchport mode trunk
switchport trunk native vlan 888
switchport trunk allowed vlan 1,254,995
no shutdown
On the C9200L the port is:
interface TenGigabitEthernet1/1/4
description **Trunk to SRL-9K**
Randomly on the Nexus 9K I'm getting these errors below:
NEXUS9K-CORE-01 %ETHPORT-5-IF_UP: Interface Ethernet1/19 is up in mode trunk
NEXUS9K-CORE-01 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/19 is down (Link failure)
NEXUS9K-CORE-01 %ETHPORT-5-SPEED: Interface Ethernet1/19, operational speed changed to 10 Gbps
NEXUS9K-CORE-01 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/19, operational duplex mode changed to Full
NEXUS9K-CORE-01 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/19, operational Receive Flow Control state changed to off
NEXUS9K-CORE-01 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/19, operational Transmit Flow Control state changed to off
On the C9200L I'm getting these errors in the log:
%LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/4, changed state to down
%LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/4, changed state to up
The transceiver I'm using is:
type is SFP-H10GB-AOC5M
name is CISCO-AVAGO
Any ideas what the issue may be?
Thank you.
open24hrs
upgrade of software solved it.
 It seems some negociation was started by 9200 and Nexus does not like.
Do the following test, put both interface in 100M.
speed 100 in both side
open24hrs
Did you upgrade software on Nexus 9K side? If so, which version you're using? I am having the same issue. Thank you
