Switch: Prompt 3650
fredrichdarren
Hi all,
I have a 3650 stuck in the switch prompt. I've tried to set the IP address using the below commands so that I can upload the IOS, but I am unable to.
set IP_ADDR
Set DEFAULT_ROUTER
below is the file system output
switch: dir
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
bs[3]: (read-only)
flash[18]: (read-only)
tftp[19]: (read-write)
I am encountering this ERROR: "The 'IP_ADDR' environment variable is not properly formatted." I'm unsure about which other IP address configuration format I should use.
Fredrich
11 Replies 11
marce1000
 - FYI : https://community.cisco.com/t5/switching/changeing-flash-from-read-only-to-read-write/m-p/3740022#M452146
 M.
Thank you, @marce1000  I will try it now.
Fredrich
fredrichdarren
I've tried all the commands given on the thread you posted; my switch is taking the below commands:
switch: set SWITCH_IGNORE_STARTUP_CFG
switch: set SWITCH_IGNORE_STARTUP_CFG 1
Then, after the boot command, the switch goes back to switch: prompt
The one below comes up with an error below:
witch: set SWITCH_IGNORE_STARTUP_CFG=1
Can't set variable with illegal char "=" (0x3d) in name.
load_helper, too, is not working; see below:
switch: load_helper
Unknown cmd: load_helper
Fredrich
 -  Try
           fsck  flash:
 M.
Thank you, @marce1000. I will try this command and advise later tomorrow. I did not get a chance to work on the switch today.
Fredrich
fredrichdarren
Hi @mblack4d
I saw you recommended some suggestions on a similar issue with my 3650 switch, and I thought you could help me. I tried the commands below to fix my 3650 switch, but after entering the boot command after these two commands, the switch goes back to the switch: prompt. Any other suggestions you may have? Thanks
Fredrich
Hello @fredrichdarren
Try following those things again :
If it is resolve again post here.
  • Reload ROMMON: Sometimes, reloading ROMMON can help resolve issues. To do this, power cycle the switch and return to ROMMON mode.
  • Since you're attempting to boot the switch, ensure the flash memory is in good condition and contains the necessary files.
  • Use dir flash: to list the contents of the flash memory and check for IOS files.
  • Use set to list all current environment variables and verify that they are correct.
Thank you, @Kumaresan Ravichandran. I will try this, too, and see how it goes. I will advise later tomorrow.
Fredrich
Leo Laohoo
Put the firmware file into a USB flash drive and execute the following command:
emergency-install usbflash0:filename.bin
Thank you, @Leo Laohoo. I tried this command, though I was using a TFTP server. It appears the file was being copied, but at the end, I got an error. I cannot remember the exact error message. I will try it again, and if I encounter the same issue, I will post it here. Thank you.
Fredrich
The command is used in ROMMON.
