NEXUS - Flexible Netflow Top talkers Configuration
ju.mahieu
hello,
I have the following FNF configuration on my Cisco Nexus 7004 chassis (F2 Modules and NX-OS Version 6.1(2):
RECORD:
feature netflow
flow record FNF-Record-L4-Session
  description FNF-Record-L4-Session-Dst-port
  match ipv4 source address
  match ipv4 destination address
  match transport destination-port
  collect counter bytes
  collect counter packets
MONITOR:
flow monitor FNF-Monitor-L4-Session
  description FNF-Monitor-L4-Session-Dst-port
SAMPLER and INTERFACE:
sampler FNF-Sampler-1000
  description FNF-Sampler-1/1000
  mode 1 out-of 10
interface Vlanxxx
  ip flow monitor FNF-Monitor-L4-Session input sampler FNF-Sampler-1000
Now, I would like to sort the cache flows in order to list the top N talkers. But it seems the "show flow monitor cache sort" doesn't exist in NX-OS.
Do you know if there is a way to do that ?
Below , the Top N talkers IOS config:
http://www.cisco.com/en/US/docs/ios/fnetflow/configuration/guide/cgf-topn.html#wp1064664
Julien
ju.mahieu
Find below the TAC answer:
CSCui71049            Bug Details
Need support to check top talker in Netflow
Symptom:
Nexus 7000 does not have the feature to check the top talkers on netflow currently.
This feature is supported on catalyst platform. Requesting this support for Nexus.
Conditions:
Nexus 7000 Netflow
Workaround:
none
Severity
6 - enhancement
So I have to wait the next release.
