Nexus - Interface is UP but configuration shows "shutdown"
cwwong1973
I am not able to find any particular bugs on Nexus 6000 running 7.1(0)N1(1a).
In the interface configuration, I notice the "shutdown" command is there but interface is actually up.
Configuration
interface Ethernet101/1/14
  switchport access vlan 1301
  spanning-tree port type edge
  shutdown
sh int eth101/1/14
Ethernet101/1/14 is up
There is traffic passing through this interface hence no issues. But unable to find any specific bugs (cosmetic?) related to the issue.
Thanks in advance
Cheers
If you do not configure a bandwidth on the subinterface and you configure the bandwidth inherit command on the main interface, the subinterfaces will inherit the ..... shutdown. Brings the port down administratively. no shutdown. Brings the port up administratively. show interface status err-disabled. .
