Nexus IOS upgrade by setting boot var and reload
CSCO12099251
With respect to bug in below link, Is there any way to check and confirm if the switch IOS had been installed by setting boot variable and reload instead of install all?
Bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy08068/?referring_site=bugquickviewredir
Godwin. S
Yachay
I am not sure how this can help you, but if you run 'sh ver', the last lines show you which the last version was and how it was upgraded (or downgraded)
Yachay
Other clue, if boot variables were set up and the switch reloaded, sometimes that doesn't update some firmwares (especially when the update is made it not following the right order of versions.) You can check it running 'show install all xxxx' and see if the version of the current firmware and the new one matches.
