nexus &k no switchport trunk command
amit bhatnagar
hello ,
I was trying to add vlan to existing trunk port on nexus 7K with 5.0(2a) image .
On perticular VDC . current configration is
interface Ethernet8/21
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 1111,1128
  channel-group 6 mode passive
  no shutdown
When I am doing command to add another vlan it doesnt give right syntax ,
# switchport tr?
% Invalid command at '^' marker.
I was trying to use command "switchport trunk add vlan 20"  please advise .
thanks for help
Amit
Reza Sharifi
Try adding it to  po6
int po6
switch trunk....
Reza Sharifi
int po6
switch trunk....
