Nexus N9K-C93180 compatibility with FEX 2248TP-E
Can someone help me with compatibility issues between Nexus N9k-C93180 and FEX 2248TP-E. I'm using NX-OS v7.0(3)|4(2).
I'm getting this error log msg:
NEXUS1# sho fex 101 det
FEX: 101 Description: FEX1 state: Image Download
FEX version: 5.2(1)N1(5) [Switch version: 7.0(3)I4(2)]
FEX Interim version: 5.2(1)N1(5)
Switch Interim version: 7.0(3)I4(2)
Module Sw Gen: 21 [Switch Sw Gen: 21]
pinning-mode: static Max-links: 1
Fabric port for control traffic: Eth1/1
Fabric interface state:
Po11 - Interface Up. State: Active
Eth1/1 - Interface Up. State: Active
Fex Port State Fabric Port
Logs:
04/09/2018 13:40:41.269428: Image preload failed.
04/09/2018 13:40:48.337759: Deleting route to FEX
04/09/2018 13:40:48.343165: Module disconnected
04/09/2018 13:40:48.344093: Module Offline
04/09/2018 13:40:48.350915: Deleting route to FEX
04/09/2018 13:40:48.354520: Module disconnected
04/09/2018 13:40:48.355661: Offlining Module
04/09/2018 13:40:48.355674: Alive timer stopped
04/09/2018 13:42:09.87056: Module register received
04/09/2018 13:42:09.87333: State timer stopped
04/09/2018 13:42:09.87689: Image Version Mismatch
04/09/2018 13:42:09.88437: Registration response sent
04/09/2018 13:42:09.88689: Requesting satellite to download image
04/09/2018 13:44:22.481247: Image preload failed.
04/09/2018 13:44:29.573044: Deleting route to FEX
04/09/2018 13:44:29.578364: Module disconnected
04/09/2018 13:44:29.579553: Module Offline
04/09/2018 13:44:29.586249: Deleting route to FEX
04/09/2018 13:44:29.589906: Module disconnected
04/09/2018 13:44:29.591036: Offlining Module
04/09/2018 13:44:29.591049: Alive timer stopped
04/09/2018 13:45:37.322128: Deleting route to FEX
04/09/2018 13:45:37.325870: Module disconnected
04/09/2018 13:45:37.327047: Offlining Module
04/09/2018 13:45:37.327069: Alive timer stopped
04/09/2018 13:45:50.78910: Module register received
04/09/2018 13:45:50.79184: State timer stopped
04/09/2018 13:45:50.79528: Image Version Mismatch
04/09/2018 13:45:50.80273: Registration response sent
04/09/2018 13:45:50.80508: Requesting satellite to download image
04/09/2018 13:47:46.503416: Image preload failed.
04/09/2018 13:47:53.572513: Deleting route to FEX
04/09/2018 13:47:53.578441: Module disconnected
04/09/2018 13:47:53.579609: Module Offline
04/09/2018 13:47:53.585930: Deleting route to FEX
04/09/2018 13:47:53.589654: Module disconnected
04/09/2018 13:47:53.590945: Offlining Module
04/09/2018 13:47:53.590958: Alive timer stopped
04/09/2018 13:49:01.322326: Deleting route to FEX
04/09/2018 13:49:01.325969: Module disconnected
04/09/2018 13:49:01.327078: Offlining Module
04/09/2018 13:49:01.327098: Alive timer stopped
04/09/2018 13:49:17.86775: Module register received
04/09/2018 13:49:17.87049: State timer stopped
04/09/2018 13:49:17.87406: Image Version Mismatch
04/09/2018 13:49:17.88203: Registration response sent
04/09/2018 13:49:17.88487: Requesting satellite to download image
04/09/2018 13:50:46.480909: Image preload failed.
04/09/2018 13:50:53.550299: Deleting route to FEX
04/09/2018 13:50:53.555534: Module disconnected
04/09/2018 13:50:53.556514: Module Offline
04/09/2018 13:50:53.563259: Deleting route to FEX
04/09/2018 13:50:53.566964: Module disconnected
04/09/2018 13:50:53.568088: Offlining Module
04/09/2018 13:50:53.568101: Alive timer stopped
04/09/2018 13:52:01.435206: Deleting route to FEX
04/09/2018 13:52:01.439201: Module disconnected
04/09/2018 13:52:01.440312: Offlining Module
04/09/2018 13:52:01.440325: Alive timer stopped
04/09/2018 13:52:17.6310: Module register received
04/09/2018 13:52:17.6577: State timer stopped
04/09/2018 13:52:17.6972: Image Version Mismatch
04/09/2018 13:52:17.7696: Registration response sent
04/09/2018 13:52:17.7930: Requesting satellite to download image
thanks,
JS
Reza Sharifi
Has this worked before or this is the first time you are connecting and upgrading the FEX?
It's the first time!
Thanks.
What is the exact part number for the switch?
Have a look at this matrix and see if your switch supports the FEX.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/hw/interoperability/fexmatrix/fextables.html
