Nexus OSPF process limit
nickjacobs
We are cutting over from 6500 IOS to Nexus 7000 and have hit "Maximum ospf feature instance limit reached." as we configured up the 7 existing ospf processes - the limit is 4. These existing processes are for various vrf contexts we have. I see you can run multiple vrf contexts under one process - but how does that work in a mixed environment where the ospf neighbours are still ios 6500s? They still expect to see different ospf process id per vrf.
We have a choice to move some routing to a different protocol - or any suggestions?
Jerry Ye
OSPF process ID is only local significant. You can estabilish OSPF adjancy with your neighbor running different OSPF process ID. This works in IOS and it should work under NX-OS also.
Rack1SW3#sh ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
4.4.4.4           1   FULL/BDR        00:00:38    155.34.34.4     FastEthernet0/21
Rack1SW3#sh ip ospf int
FastEthernet0/21 is up, line protocol is up (connected)
  Internet Address 155.34.34.3/24, Area 100
  Process ID 200, Router ID 3.3.3.3, Network Type BROADCAST, Cost: 1
  Transmit Delay is 1 sec, State DR, Priority 1
  Designated Router (ID) 3.3.3.3, Interface address 155.34.34.3
  Backup Designated router (ID) 4.4.4.4, Interface address 155.34.34.4
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    oob-resync timeout 40
    Hello due in 00:00:02
  Supports Link-local Signaling (LLS)
  Cisco NSF helper support enabled
  IETF NSF helper support enabled
  Index 1/1, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 0, maximum is 1
  Last flood scan time is 0 msec, maximum is 0 msec
  Neighbor Count is 1, Adjacent neighbor count is 1
    Adjacent with neighbor 4.4.4.4  (Backup Designated Router)
  Suppress hello for 0 neighbor(s)
Rack1SW4#sh ip ospf nei
3.3.3.3           1   FULL/DR         00:00:30    155.34.34.3     FastEthernet0/21
Rack1SW4#sh ip ospf int
  Internet Address 155.34.34.4/24, Area 100
  Process ID 100, Router ID 4.4.4.4, Network Type BROADCAST, Cost: 1
  Transmit Delay is 1 sec, State BDR, Priority 1
    Hello due in 00:00:09
  Next 0x0(0)/0x0(0)
  Last flood scan length is 1, maximum is 1
  Last flood scan time is 0 msec, maximum is 4 msec
    Adjacent with neighbor 3.3.3.3  (Designated Router)
HTH,
jerry
Jerry Ye
  Next 0x0(0)/0x0(0)
  Next 0x0(0)/0x0(0)
HTH,
jerry
Indeed - so worried about differences I am forgetting first principles. Confrimed OK.
