07-11-2013 01:19 AM - edited 03-07-2019 02:20 PM
We need to run port channel between nexus 5K and cisco ASA.
Do we need to use FEX or normal SFP(10-SR) or GLC-T would be sufficient.
and is there any difference in configuration for port channel as this is nexus.
Thanks!
Solved! Go to Solution.
07-11-2013 07:03 AM
It is actually called FET (Fabric Extender Transceiver).
You can only use FET between the fabric extenders e.g 2248, 2232, etc.. and the 5k or 7k.
As indicated by Inayath, if your distance is short you can use GLC-T, if not then SFP for Gig or SFP+ for 10Gig.
07-11-2013 01:29 AM
You can use GLC-T or SFP to form port-channel between 5K and ASA.
Inayath
07-11-2013 07:03 AM
