04-09-2019 06:15 AM
Does anyone know if the Nexus 3548's are capable of the port-security feature? I'm getting a "not supported on this platform" message. Is this a limit of the hardware or IOS? We're running n3500-uk9.6.0.2.A8.7b.bin. If this is a IOS issue does anyone know which release supports port-security?
04-09-2019 06:20 AM
04-09-2019 06:38 AM
I know it's a global command using the feature command to enable it but that doesn't work. enabling the feature I get an error.
(config)# feature port-security
Port-security is not supported on this platform
I don't think switching from n3500-uk9.6.0.2.A8.7b.bin to 6.0(2)A8(11) will help. There is a 7.0(3)I7(6) available but the description is "Cisco Nexus 9000/3000 Standalone Switch" and I don't think that will work in our environment. Port-security is a common config, so it seems strange that I can't enable it on this model with this image and as I see there are no licensing requirements for this feature either?
04-09-2019 07:06 AM
04-09-2019 07:12 AM
Thanks Mark, I opened a case with Cisco to get a definitive answer. I'm being to believe it is IOS related. I'll post what Cisco says is anyone else has this issue.
Thanks Bob.
04-09-2019 06:40 AM
You need to enable ( by default it was disabled)
to check enable or disable
config t
(config)# show port-security ( you will not see this command that means feature not enabled.
(config)#show port-security
04-09-2019 06:45 AM
(config)# sh port-security
% Invalid command at '^' marker.
04-09-2019 07:09 AM
strange : can you please show us show version
back i believe tested with 7.X
04-09-2019 07:09 AM - edited 04-09-2019 07:10 AM
I dont see it any release notes for 3548 models , its in the 3k general series but 7 has it supported as per the link
04-09-2019 07:25 AM
Seems the 3548 doesn't support the port-security feature.
This is Cisco's response:
Unfortunately, there are no current plans to support port-security on Nexus 3548.
There are some commands available in the software, but as you have found, they do not work. This is why there is no configuration guide for port-security on N3K.
04-09-2019 08:12 AM
