11-21-2011 09:06 AM - edited 03-07-2019 03:30 AM
I am using cisco Nexus5548 and trying to enter a snmp community, but it doesn't accept it. It shows:
NEXUS# snmp-server community <name> ro
Error : Not a valid Community Name
I enter a community name that is less than 32 characters, with symbols, numbers and letters. Any clues?
thank you.
Solved! Go to Solution.
11-21-2011 08:11 PM
Make sure you are not using @ sign.
When doing a snmp V2 get, one can append "@
Nik
11-21-2011 02:28 PM
ro Error : Not a valid Community Name
thank you.
Are you actually in configuration mode (issued the "configure terminal" command) when you issue this command?
If this is a direct cut and paste from your screen, the prompt would indicate that you're not - to enter this command, you need to be at the
NEXUS(config)#
prompt.
Cheers.
11-21-2011 08:11 PM
Nik
