Nexus1010 Did not receive supstate notification in 180 seconds. Still waiting
sokarlsson
After reboot due to powerfail our primary Nexus 1010 fails to boot. Output from console:
Auto booting bootflash:/nexus-1010-kickstart-mz.4.2.1.SP1.3.bin bootflash:/nexus-1010-mz.4.2.1.SP1.3.bin...
Booting kickstart image: bootflash:/nexus-1010-kickstart-mz.4.2.1.SP1.3.bin................................................................Image verification
OK
Starting kernel...
PCI: PIIX3: Enabling Passiv%H+¬)6%è¹
                                     ƒ00ñ.¬©íUsage: init 0123456SsQqAaBbCcUu
mkdir: cannot create directory `/new-root/old-root': File exists
INIT: version 2.85 booting
Bootflash device is /dev/hda
Checking all filesystems....r. done.
Setting kernel variables: sysctlnet.ipv4.ip_forward = 0
net.ipv4.ip_default_ttl = 64
net.ipv4.ip_no_pmtu_disc = 1
/etc/rc.d/rcS.d/S35iptables: line 41: //iptables: No such file or directory
/etc/rc.d/rcS.d/S35iptables: line 44: //ip6tables: No such file or directory
Loading system software
Uncompressing system image: bootflash:/nexus-1010-mz.4.2.1.SP1.3.bin
Load plugins that defined in image conf: /isan/plugin_img/img.conf
load_plugin: failed read swid map from "/mnt/pss/plugin_swid_map" with rc 0xffffffff. Plugin will be assigned new ID
Loading plugin 0: core_plugin...
load_plugin: Can't get exclude list from /isan/plugin/0/boot/etc/plugin_exclude.conf (rc 0x40ea0017)
plugin_link_to_exec_path: plugin_path = /isan/plugin/0, tar_log = /isan/plugin_extract_log/0
num srgs 1
0: swid-core-sup1sfp, swid-core-sup1sfp
num srgs 1
0: swid-sup1sfp-ks, swid-sup1sfp-ks
INIT: Entering runlevel: 3
Starting dhcpd daemon: dhcpdInternet Systems Consortium DHCP Server V3.0.1rc14
Copyright 2004 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
Wrote 0 deleted host decls to leases file.
Wrote 0 new dynamic host decls to leases file.
Wrote 0 leases to leases file.
Not configured to listen on any interfaces!
Exporting directories for NFS kernel daemon...done.
Starting NFS kernel daemon:rpc.nfsd.
rpc.mountddone.
/bin/mkdir: cannot create directory `/bootflash/repository': File exists
/isan/bin/mount_cppa_repository exist
2012 Feb 15 13:11:59 NTM-DC-VSA-01 %SYSLOG-2-SYSTEM_MSG: Did not receive supstate notification in 180 seconds. Still waiting
Last message "%SYSLOG-2-SYSTEM_MSG: Did not receive supstate notification in 180 seconds. Still waiting "
Repeats 5-6 time every 180 seconds and then the appliance restarts by itself.
Do I need to reinstall?
sokarlsson
If anyone runs into this. I had to reinstall the Nexus 1010 software to resolve this.
Does anybody has another answer, because i have reinstalled it but i continue with this issue?????
SOKARLSSON, what number of version did you install??
Thanks !!!!
At that time I just reinstalled the primary with 4.2(1)SP1(3). Have you reinstalled from the ISO removing ALL config from the node that is not syncronizing?
