Nexus7700 VDC Features
haitham.jneid
Hi Experts,
I have purchased a VDC license for nexus7700 and I need to install it and enable the features below. after I copy the license to the bootflash and Install it,create the VDC and allocate interfaces as the following:
Switch# copy usb1://file_License.lic file_License.lic
switch# install license bootflash:file_License.lic
Creating VDC and Assigning Interfaces:
vdc RYD-ENT-01
  allocate interface Ethernet2/25-32
the below configuration is enough to enable these features or I need to use the install-set feature command. please support.
Enabling Features
feature sftp-server
feature tacacs+
cfs eth distribute
feature ospf
feature bgp
feature pbr
feature udld
feature interface-vlan
feature lacp
feature glbp
feature vpc
feature bfd
feature sla sender
feature sla responder
feature ssh
Reza Sharifi
This should be enough to enable VDCs. The "install feature-set" is mainly for virtualization and fabric path.
