06-21-2014 11:10 AM - editado 03-07-2019 07:48 PM
We have N7K-F248XP-25E in which interfcae 3/5 to 3/8 has been assigned to one VDC.
in which we want to make one interface L2 and one port interface L3 but we are getting the below error...
ERROR: Ethernet3/7: requested config change not allowed
Can we L2 and L3 in same port-group ?
Solucionado! Ir para a Solução.
em 06-21-2014 01:47 PM
Yes, if your remove the M1 card, then you should be able to create a layer-3 interface.
em 06-21-2014 11:22 AM
Can you try this command?
vdc limit-resource module-type f2e
and test again?
em 06-21-2014 11:28 AM
I am using F2E card with M1 card . is it possible to create L3 interfcae on F2E then ?
em 06-21-2014 11:37 AM
In the same VDC or separate VDC?
em 06-21-2014 11:40 AM
Both cards's interfaces in same VDC
II have created four VDC in N7K. If i remove the M1 ports from one particulat VDC then would i able to make L3 interface on this VDC then ?
this is very important for us
em 06-21-2014 09:23 PM
Hi Reza
Thanks for the help
If i am using F2E card as an L3 then is there any limitations ? we need to run the EIGRP on this F2E card
em 06-22-2014 08:17 AM
I have never use EIGRP on Nexus device, but it should work fine. EIGRP is the function of the software and as long as the interface can do layer-3, you should be able to add it to EIGRP process.
em 06-21-2014 11:41 AM
from the data sheet:
When deploying the Cisco Nexus 7000 F2e-Series Copper Module in a VDC together with the Cisco Nexus 7000 M-Series modules, the Cisco Nexus 7000 F2e-Series Copper Module will run in Layer 2-only mode, delegating all Layer 3 capabilities to the Cisco Nexus 7000 M-Series modules present in the VDC.
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/data_sheet_c78-719524.html
em 06-21-2014 11:45 AM
Hi Reza
Thanks for all your help.This is very critical to get to know this
We have N7K-F248XP-25E "Nexus 7000 F2-Series 48 Port 1/10G (SFP+) Enhanced"
F2E SFP Module , if i remove all the M1 interfaces from that VDC then would i able to use the F2E port as an L3 ?
in other VDC , port can be combined ?
em 06-21-2014 12:28 PM
I have allocated all the F2E interfaces to one VDC but still i am not able to give the ip addressess to interface
is there any feature in need to start ?
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
