Nexus9504 Interface flap
Alex Hwang
Frequent Visitor
Frequent Visitor
Hi guys,
One of the physical interface which is member of a port-channel with VPC is flapping with logs below.
It is happening a couple of times per day.
The physical link(10GBase-LR) status looks good - TX/RX Power levels are in normal range with no CRC/errors.
Any ideas what would cause this issue?
2018 Aug 7 04:18:47.875 N95-02 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel21: Ethernet2/1 is down
2018 Aug 7 04:18:47.910 N95-02 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel21: first operational port changed from Ethernet2/1 to none
2018 Aug 7 04:18:48.076 N95-02 %ETHPORT-5-IF_DOWN_INITIALIZING: Interface Ethernet2/1 is down (Initializing)
2018 Aug 7 04:18:51.290 N95-02 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel21: Ethernet2/1 is up
2018 Aug 7 04:18:51.393 N95-02 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel21: first operational port changed from none to Ethernet2/1
2018 Aug 7 04:18:51.405 N95-02 %ETHPORT-5-IF_UP: Interface Ethernet2/1 is up in mode trunk
cassiolange
Level 5
Level 5
Hello Alex,
Look in Ethernet Port Manager logs
show system internal ethpm event-history interface ethernet 2/1
LACP logs
show lacp internal event-history interface ethernet 2/1
N7K Tshoot guide
http://docwiki.cisco.com/wiki/Cisco_Nexus_7000_Series_NX-OS_Troubleshooting_Guide_--_Troubleshooting_Ports
Good luck
