Switching
Labels
Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Monday, February 2, 2026, through Friday, February 20, 2026. Our colleagues Amruta Navadagi, Anaya Kalawat, and Mohammad Mehtabuddin will be waiting to assist you...
amnavada by • Cisco Employee
  • 16801 Views
  • 36 replies
  • 2 Helpful votes
I am looking for a feature/command on Nexus 9K device.  The requirement is to drop mcast packets on trunk ports on a certain vlan but only on certain trunk ports. For example Port 1 and 2 is a trunk port each carrying vlan 100 and 200.  I want to blo...
HiI need some rack ears for an SG300-28PPCan anyone please tell me the part number, and where in the UK I can get these rom? Note, these are NOT the same across all the SG range.... I've already been there!TIA
Future Media by • Community Member
  • 1949 Views
  • 4 replies
Hi ,We have SGT capable devices such as Meraki MR , Meraki MX , and Access switches. However , our core ( Arista ) is not SGT capable ( haven't tested but doesn't look capable ).I have read some blogs and articles about SXP but I'm fairly new to all ...
Raphael_L by • Meraki Community All-Star
  • 751 Views
  • 3 replies
I have a C9500-48Y4C IOS XE 17.12.4 that is notifying of a lot of MAC flapping. This is the typical error log. Oct 27 13:14:41.253: %SW_MATM-4-MACFLAP_NOTIF: Host 0050.56b1.96a0 in vlan 412 is flapping between port Twe1/0/3 and port Po1When the switc...
rlwilson by • Visitor
  • 3409 Views
  • 6 replies
We have remote office with 5 MS130-48PSW01 which we can call the "core"  Layer 2 only has crashed 3 times over the last two weeks, where it reports offline in the dashboard and stops passing traffic.To bring the network back up we have to pull the po...
RobTR by • Community Member
  • 108 Views
  • 1 replies
Hey!Cisco Catalyst 9300 L2 guide explicitly states that the command ptp mode:"Specifies the synchronization clock mode: - boundary: to enable the switch to participate in selecting the best master clock. If no better clocks are detected, the switch b...
rootswitch by • Frequent Visitor
  • 235 Views
  • 1 replies
i have essential license of cisco 9500L switch but i am unable to create stack wise virtual to create stack wise virtual i enable #license boot level network-advantage addon DNA-advantage command, now stack wise virtual is working but could be pleas ...
mhassan01 by • Community Member
  • 343 Views
  • 8 replies
I have a stack of 4 C9200L-48P-4X switches running 17.09.05 cat9_lite_iosxe which I cant upgrade.I tried copying the 17.18.04 to flash: but cant install due to insufficient memory.Now I put a usb drive in the switch and ran: install add file ...activ...
Nout by • Level 1
  • 398 Views
  • 12 replies
I bought a Cisco Catalyst switch from a hamfest (amateur radio swap meet) and am trying to get it working.  I am a retired software engineer and am just looking to get this working.  I can connect to it through a serial conection and can run some ini...
