NIC bonding on Barracuda Backup using 3650 switch
sbrock
Looking for help to bond 2 NICs on a Barracuda Backup appliance.  The 2nd NIC on the appliance has been activated by Barracuda support.  If NIC 2 (connected to gi1/0/8) is active, I can not ping the device.  If I shutdown port gi1/0/8, I can ping the device.  What am I missing?
My switch configuration is:
interface Port-channel10
switchport access vlan 100
switchport mode access
end
interface GigabitEthernet1/0/7
channel-group 10 mode on
spanning-tree portfast
end
interface GigabitEthernet1/0/8
end
From Barracuda's knowledge base:
Link Aggregation (LAG) allows you to bond two or more ports in parallel to achieve greater throughput. LAG has the following properties:
  • LAG provides automatic recovery when individual physical links fail. As long as at least one physical link exists, the LAG connection continues to exist.
  • Data transmission is distributed as frames over the physical links.
  • All frames forming part of a specific data communication packet are transmitted over the same physical connection, ensuring delivery of the individual frames of a data communication packet in the correct order, preventing disordering.
Barracuda Networks uses Mode 4 (802.3ad) bonding, known as Dynamic Link Aggregation mode. This mode creates aggregation groups that share the same speed and duplex settings, and requires a switch that supports IEEE 802.3ad Dynamic link.
Mark Malone
did you try LACP instead as its sayin IEEE 802.3ad your using on mode no negotiation , if its bundled on your end P in the etherchannel output and its still not working , chances are they havent teamed their end correctly
I remotely remember that you have to disable spanning tree on the port channel:
--> spanning-tree bpdufilter enable
end
end
end
