NM-16ESW Solution
jeff.carr
Need to find out if this solution will work.
I want to install a NM-16ESW into a 2811 ISR. I would like to configure 16 individual VLAN interfaces and assign each physical port to one of the VLANs.
Will the router/module support that number of VLANs? Each VLAN interface will have it's own IP address in a separate network. Will I be able to successfully route between all of the different subnets using EIGRP?
Thanks.
Edison Ortiz
You can configure up to 256 Vlans. Your proposed design will work.
HTH,
__
Edison.
Edison Ortiz
HTH,
__
Edison.
Acknowledged. Thanks for the reply.
