NM-1FE-TX does not work with 2691 Router
mahesh18
Level 6
Level 6
*** Address Parity Error ***
PC = 0xbfc00d20, Cause = 0xd4000, Status Reg = 0x3041e803
Failure detected during ROMMON start-up tests. Restart ROMMON.
System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2002 by cisco Systems, Inc.
Can somebody please tell me why this error came?
only thing i did was insert external CF  card on router.
That card is blank it has no IOS on it.
I did power cycle the router it is stuck at
c2691 processor with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x80008000, size: 0xcd60
program load complete, entry point: 0x80008000, size: 0x245ac68
Self decompressing the image : #################################################
######################################################################## [OK]
should i again  reboott the router?
thanks
mahesh18
Level 6
Level 6
More info on issue---
i inserted this FE  card on router
NAME: "Unknown", DESCR: "Unknown"
PID: NM-1FE-TX=        , VID: 1.0, SN: 12949267
nt detected on slot 1
OIR not supported on this platform
Inserting or removing modules while powered on may cause router to crash!
again i rebooted the card.
when i inserted it router console says
i reloaded the router but it do not see new FE  port
Slot 1:
        Unknown (type 68) Port adapter
        Port adapter is disabled
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware revision 1.0           Board revision D0
        Serial number     12949267      Part number    800-03490-02
        FRU Part Number     NM-1FE-TX=
        Test history      0x0           RMA number     00-00-00
        EEPROM format version 1
        EEPROM contents (hex):
          0x00: 01 44 01 00 00 C5 97 13 50 0D A2 02 00 00 00 00
          0x10: 68 0A 21 00 99 04 12 00 FF FF FF FF FF FF FF FF
          0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF
is this card FE  not compatible with router ?
card has green lights on link and 100mbps.
thanks
mahesh
More info
Router has latest IOS
Router# sh ver
Cisco IOS Software, 2600 Software (C2691-ADVENTERPRISEK9-M), Version 12.4(25d),
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 05:35 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
Router uptime is 34 minutes
System returned to ROM by reload
System image file is "flash:c2691-adventerprisek9-mz.124-25d.bin"
