NM-2FE2W-V2 Card installation problems
oukpaka
I tried to do an installation of the NM-2FE2W-V2 module on the a Cisco 3640 router. After installation the C3640 keeps rebooting.
Attached are the errors generated during reboot.
gpulos
Level 8
Level 8
Your IOS version does not support the NM-2FE2W-V2.
from your output:
"Cisco Internetwork Operating System Software
IOS (tm) 3600 Software (C3640-I-M), Version 12.0(9), RELEASE SOFTWARE (fc1)"
You need a minimum IOS version of 12.2(12)+ to operate the hardware.
Upgrade your IOS and you should get a workable router.
One note, the NM-2FE2W-V2 has been End-Of-Life for a few years now.
Please see the following link for info on IOS upgrade:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00801fc986.shtml
