NM-2FE2W-V2 in a 2821, how to configure?
ted.schwind
I do not see the 2 FE ports in sh ip int br. I don't see how to enable the card. card-type is not an option
show version
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.3(11)T11, RELEASE SOFTWARE (fc3)
Cisco 2821 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FTX1041A2KL
3 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
show diag
Slot 1:
        Unknown (type 919) Port adapter
        Port adapter is disabled
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-21601-02
        Board Revision           : B0
        Deviation Number         : 0-0
        Fab Version              : 01
        PCB Serial Number        : JAE0826MRLG
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : NM-2FE2W-V2=
ted.schwind
never mind. The card does not appear to be supported.
