No console output on Nexus5020 after FW upgrade
vijay.gaganam
Cisco Nexus 5020 Firmware is upgraded. Upgrade was successfull without any issue. After reboot nothing comes up on the console. Tried rebooting a couple of times. nothing comes up on the console, not even the inital Bios output.
Anybody know if its a hardware or software issue.
Upgrade procedure followed.
Cisco5020# copy ftp bootflash:n5000-uk9.4.2.1.N1.1.bin
Enter vrf (If no input, current vrf 'default' is considered): management
Enter username: **********
Password: *************
***** Transfer of file Completed Successfully *****
Cisco5020# copy ftp bootflash:n5000-uk9-kickstart.4.2.1.N1.1.bin
install all system bootflash:n5000-uk9.4.2.1.N1.1.bin kickstart bootflash:n5000-uk9-kickstart.4.2.1.N1.1.bin
Verifying image bootflash:/n5000-uk9-kickstart.4.2.1.N1.1.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.4.2.1.N1.1.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n5000-uk9.4.2.1.N1.1.bin.
Extracting "kickstart" version from image bootflash:/n5000-uk9-kickstart.4.2.1.N1.1.bin.
Extracting "bios" version from image bootflash:/n5000-uk9.4.2.1.N1.1.bin.
Notifying services about system upgrade.
Compatibility check is done:
Module bootable         Impact Install-type Reason
     1       yes     disruptive         reset Reset due to single supervisor
Images will be upgraded according to following table:
Module       Image         Running-Version             New-Version Upg-Required
     1     system             4.1(3)N1(1)             4.2(1)N1(1)           yes
     1   kickstart             4.1(3)N1(1)             4.2(1)N1(1)           yes
     1       bios       v1.2.0(06/19/08)                                   no
Switch will be reloaded for disruptive upgrade.
Do you want to continue with the installation (y/n)? [n] y
Install is in progress, please wait.
Setting boot variables.
Performing configuration copy.
Module 1: Refreshing compact flash and upgrading bios/loader/bootrom.
Warning: please do not remove or power off the module at this time.
Finishing the upgrade, switch will reboot in 10 seconds.
Cisco5020#
Broadcast message from root (Thu Aug 26 21:14:55 2010):
The system is going down for reboot NOW!
ayyanar.perumal
I also hit same problem after updating to 5.0(2)N2(1) version in Cisco Nexus 5020.
Anybody knows why??
Tried connecting to console we are not seeing any output.
Sould like the BIOS got corrupted. I will suggest you to open a TAC case to further troubleshoot.
HTH,
jerry
Are you able to telnet or ssh to it?
Did you try to use any other consile cable?
If you are not able to ssh adn telnet and not able to console it looks like a hardware failure.
You can also try to reboot it by taking off powercable and plugin it back.
