02-01-2017 06:37 AM - edited 03-08-2019 09:08 AM
I just setup a Cisco Air 1142 in autonomous mode. Seems to be working just fine, but if I try to join the 5Ghz WiFi is does not give out an IP address. 2.4Ghz is working as it should. Below is the current config, any advise would be greatly appreciated.
Office_WiFi#show run
Building configuration...
Current configuration : 2577 bytes
! Last configuration change at 01:11:21 UTC Fri Mar 1 2002 by Cisco
version 15.3
no service pad
service password-encryption
hostname Office_WiFi
logging rate-limit console 9
enable secret 5 $1$hdg4$vkcOcC/EPbRj2ClnIevpe1
no aaa new-model
no ip source-route
no ip cef
ip domain name woodchipstudios.com
dot11 syslog
dot11 ssid It Burns When IP
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 122D121E1C00050109242B233A30754257
dot11 ssid It Really Burns When IP
vlan 30
authentication open
guest-mode
wpa-psk ascii 7 08155B4707120C123104030F232E737963
no ipv6 cef
username Cisco password 7 05280F1C2243
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
encryption vlan 30 mode ciphers aes-ccm
antenna gain 0
peakdetect
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.30
encapsulation dot1Q 30
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 spanning-disabled
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
interface GigabitEthernet0
ip address 192.168.1.28 255.255.255.0
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0.30
bridge-group 30
interface BVI1
mac-address 0022.bd18.3f23
ip address 192.168.1.27 255.255.255.0
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community WiFi RW
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
02-01-2017 07:26 AM
You are associating 5Ghz with vlan 30 and bridge group 30. But I do not see anything that associates any IP with them. I would have thought that there would be something like BVI30 to do this.
Rick
02-01-2017 07:34 AM
So would this work:
no BVI1
BVI30
no bridge-group 1
no bridge-group 1 subscriber-loop-control
no bridge-group 1 spanning-disabled
no bridge-group 1 block-unknown-source
Sorry a little new to Access points.
02-01-2017 07:52 AM
Access points are not a particular area of strength for me either. But it seems to me that if you remove BVI1 and replace it with BVI30 that you will impact the 2.4Ghz. Perhaps we should start by clarifying what you are trying to achieve. Do you want the 2.4 and the 5 Ghz to use different IP subnets? Or do you want them both in the same subnet? If you want two subnets then I believe that you will need two bridge groups and two BVIs. If you want them in the same subnet then there would be one bridge group used on both and one BVI.
Rick
02-01-2017 10:08 AM
Ok, so I have this now (after some Googling), but when I join the 5Ghz it doesn't give me an IP. Am I missing something here?
Current configuration : 3268 bytes
! Last configuration change at 04:43:46 UTC Fri Mar 1 2002 by Cisco
version 15.3
no service pad
no aaa new-model
no ip source-route
no ip cef
dot11 syslog
dot11 vlan-name 2.5Ghz vlan 1
dot11 vlan-name 5Ghz vlan 10
vlan 1
authentication open
mbssid guest-mode
wpa-psk ascii 7 0030040F0A5002032C2E4345001C524642
vlan 10
authentication open
mbssid guest-mode
wpa-psk ascii 7 02321352050D06246F4106120C12455A5C
no ipv6 cef
bridge irb
no ip address
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 10 mode ciphers aes-ccm
antenna gain 0
beamform ofdm
mbssid
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
interface Dot11Radio0.10
encapsulation dot1Q 10
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
no ip address
antenna gain 0
peakdetect
no dfs band block
beamform ofdm
mbssid
channel dfs
station-role root
interface Dot11Radio1.1
bridge-group 1
interface Dot11Radio1.10
bridge-group 10
duplex auto
speed auto
interface GigabitEthernet0.1
bridge-group 1
interface GigabitEthernet0.10
bridge-group 10
interface BVI1
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
02-01-2017 11:18 AM
When you have configured bridge irb and have bridge group 1 then it expects to communicate using BVI 1. And when you have bridge group 10 then it expects to communicate using BVI 10. So let me repeat my question from an earlier response: "Perhaps we should start by clarifying what you are trying to achieve. Do you want the 2.4 and the 5 Ghz to use different IP subnets? Or do you want them both in the same subnet?" The answer to that question should indicate whether you want one bridge group or two bridge groups. Until that is clarified we will not be able to determine which is the correct configuration.
Rick
02-01-2017 11:20 AM
Sorry my bad for not answering that. Same subnet, just different freq for the same network.
02-01-2017 11:43 AM
Thank you for the clarification. In this case you need only a single bridge group and a single BVI. Both radios use the same bridge group and the same BVI.
Rick
