no link between 2 10Gbase-SR
Marko Leopold
Level 6
Level 6
Hello!
Actually we have a little problem. We have 2 6509 (Switch1 and Switch2) running on 12.2.(33) SXI. Both switches has the same modules inside (look at the show module output). We try to form a portchannel with 2x 10GB over slot 1 and slot 3. We want to use interface Ten3/16 and Ten1/1. Ten1/1 is showing connected when wiring together. Ten3/16 dont work at all. We tried using different X2-modules. Tried changing cables. Reset of module didnt worked. Disabling and enabling oversubscription-mode didnt worked. We used other port (like Ten3/2) but the link didnt came up at all. Does anyone has any idea left, except reboot the switch, what we will do next time we get a maintenance window? The configuration is running on 2 other pairs of 6509 without any problems.
Down there i put all the output i think that is important. Configuration and show interface status is the same on both switches.
Kind regards,
Marko
Port         Name               Status       Vlan       Duplex  Speed Type
Te1/1        Trunk_Switch2_1/1 connected    trunk        full    10G 10Gbase-LX4
Te1/2        Trunk_Switch3_1/0 connected    trunk        full    10G 10Gbase-LR
Te1/3                           disabled     routed       auto   auto No Connector
Te1/4                           disabled     routed       auto   auto No Connector
Te3/1        Enclosure_BEA_1    connected    trunk        full    10G 10Gbase-SR
Te3/2                           notconnect   routed       full    10G No Connector
Te3/3                           disabled     routed       auto   auto No Connector
Te3/4                           disabled     routed       auto   auto No Connector
Te3/5        Enclosure_BEA_1    connected    trunk        full    10G 10Gbase-SR
Te3/6                           disabled     routed       auto   auto No Connector
Te3/7                           disabled     routed       auto   auto No Connector
Te3/8                           disabled     routed       auto   auto No Connector
Te3/9        Enclosure_BEA_2    connected    trunk        full    10G 10Gbase-SR
Te3/10                          disabled     routed       auto   auto No Connector
Te3/11                          disabled     routed       auto   auto No Connector
Te3/12                          disabled     routed       auto   auto No Connector
Te3/13       Enclosure_BEA_2    connected    trunk        full    10G 10Gbase-SR
Te3/14                          disabled     routed       auto   auto No Connector
Te3/15                          disabled     routed       auto   auto No Connector
Te3/16       Trunk_Switch2_3/1 notconnect   1            full    10G 10Gbase-SR
Time Stamp         ET [Card] Event Message
05/19 20:10:47.499 E  [3]    check_ether_packet [3/16]: newpak is NULL!
05/19 20:10:47.531 E  [3]    hm_test_ndl_port_for_heathland[3/16]: check_ether
                             _802dot1q_packet failed (err-code 43)
05/19 20:13:32.640 E  [3]    diag_skip_test_or_port [3]: diag_get_run_info_reg
                              failed
Switch1# sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI, RELEASE SOFTWARE (fc2)
Technical Support:
http://www.cisco.com/techsupport
Switch1#sh module
Mod Ports Card Type                              Model              Serial No.
  1    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      XXXXXXXXXXX
  3   16  CEF720 16 port 10GE                    WS-X6716-10GE      XXXXXXXXXXX
  4    6  Firewall Module                        WS-SVC-FWM-1       XXXXXXXXXXX
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       XXXXXXXXXXX
  6   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     XXXXXXXXXXX
  7   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     XXXXXXXXXXX
  8   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     XXXXXXXXXXX
  9   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     XXXXXXXXXXX
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0007.0e32.0fec to 0007.0e32.0fef   2.6   12.2(14r)S5  12.2(33)SXI  Ok
  3  001f.6ca4.1b48 to 001f.6ca4.1b57   1.1   12.2(18r)S1  12.2(33)SXI  Ok
  4  0007.0e7b.f718 to 0007.0e7b.f71f   4.2   7.2(1)       3.1(16)      Ok
  5  0019.e7d3.ce04 to 0019.e7d3.ce07   5.4   8.4(2)       12.2(33)SXI  Ok
  6  001d.45ba.0430 to 001d.45ba.045f   2.6   12.2(14r)S5  12.2(33)SXI  Ok
  7  001d.455f.6140 to 001d.455f.616f   2.6   12.2(14r)S5  12.2(33)SXI  Ok
  8  001d.45ba.2fe0 to 001d.45ba.300f   2.6   12.2(14r)S5  12.2(33)SXI  Ok
  9  001d.455f.6350 to 001d.455f.637f   2.6   12.2(14r)S5  12.2(33)SXI  Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       XXXXXXXXXXX  4.0    Ok
  3  Distributed Forwarding Card WS-F6700-DFC3C     XXXXXXXXXXX  1.4    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3B       XXXXXXXXXXX  2.3    Ok
  5  MSFC3 Daughterboard         WS-SUP720          XXXXXXXXXXX  3.0    Ok
  6  Centralized Forwarding Card WS-F6700-CFC       XXXXXXXXXXX  4.0    Ok
  7  Centralized Forwarding Card WS-F6700-CFC       XXXXXXXXXXX  4.0    Ok
  8  Centralized Forwarding Card WS-F6700-CFC       XXXXXXXXXXX  4.0    Ok
  9  Centralized Forwarding Card WS-F6700-CFC       XXXXXXXXXXX  4.0    Ok
Mod  Online Diag Status
  1  Pass
  3  Pass
  4  Pass
  5  Pass
  6  Pass
  7  Pass
  8  Pass
  9  Pass
Switch1#sh run int po 50
Building configuration...
Current configuration : 135 bytes
interface Port-channel50
description Channel_Switch2
switchport
switchport mode trunk
end
Switch1#sh run int ten1/1
Current configuration : 174 bytes
interface TenGigabitEthernet1/1
description Trunk_Switch2_1/1
switchport
channel-group 50 mode active
end
Switch1#sh run int ten3/16
Current configuration : 138 bytes
interface TenGigabitEthernet3/16
description Trunk_Switch2_3/16
switchport
End
Switch1#sh diagnostic result module 3
Current bootup diagnostic level: minimal
Module 3: CEF720 16 port 10GE  SerialNo : SALXXXXXXX
  Overall Diagnostic Result for Module 3 : PASS
  Diagnostic level at card bootup: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
    1) TestOBFL ------------------------> .
    2) TestTransceiverIntegrity:
      Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16
            .  U  U  U  .  U  U  U  .  U  U  U  .  U  U  .
    3) TestNonDisruptiveLoopback:
            .  .  U  U  .  U  U  U  .  U  U  U  .  U  U  .
    4) TestLoopback:
    5) TestScratchRegister -------------> .
    6) TestSynchedFabChannel -----------> .
    7) TestNewIndexLearn ---------------> U
    😎 TestDontConditionalLearn --------> U
    9) TestCapture ---------------------> U
   10) TestTrap ------------------------> U
   11) TestMacNotification -------------> .
   12) TestFibDevices ------------------> .
   13) TestIPv4FibShortcut -------------> .
   14) TestIPv6FibShortcut -------------> .
   15) TestNATFibShortcut --------------> .
   16) TestMPLSFibShortcut -------------> .
   17) TestL3Capture -------------------> U
   18) TestL3VlanMet -------------------> .
   19) TestIngressSpan -----------------> .
   20) TestEgressSpan ------------------> .
   21) TestAclPermit -------------------> .
   22) TestAclDeny ---------------------> .
   23) TestQos -------------------------> .
   24) TestNetflowShortcut -------------> .
   25) TestFibTcamSSRAM ----------------> U
   26) TestAsicMemory ------------------> U
   27) TestEobcStressPing --------------> U
   28) TestFirmwareDiagStatus ----------> .
   29) TestAsicSync --------------------> .
   30) TestUnusedPortLoopback:
            U  U  U  .  U  U  U  .  U  U  U  .  U  U  .  U
   31) TestErrorCounterMonitor ---------> U
   32) TestPortTxMonitoring:
            .  U  U  U  .  U  U  U  .  U  U  U  .  U  U  U
   33) TestRwEngineOverSubscription ----> U
0 Replies 0
