what switch to use?
IngGerardo013
Hello guys,
somebody knows what is the minimun switch (talking about level of complex) to connect it to a access point controller 4402 (4 12 APs) ?
can be a 2960 LAN lite?
The problem is the low budget to the proyect.
Leo Laohoo
Ok.  You got a 4402 with 12 APs?
Firstly, you need to get a switch that can support Dot1Q trunking and with GigabitEthernet port (minimum of 1 and maximum of 2).  The WLC will not support 10/100BaseTx and only 1Gbs.  What SFP are you using?  GLC-T, GLC-SX-MM, GLC-LH-SM?
Next issue is how is your AP going to get powered up. Do you need PoE or power injector?
So with this you have a good reference of what switch to get.  You can start with Linksys un-managed switches to Cisco.  With Cisco you can trawl e-bay for the most basic WS-C2950T if you are using GLC-T on the WLC.  You can use 2950SX or 2950G if you are using GLC-SX-MM.  2950G if you are using GLC-LH-SM.
PS:  If you need power supply for the 1130 or 1240 let me know (or earlier).  I have a stack full and I'm willing to part with it!
If you can provide more information we can help you a bit more.
Don't forget to rate our posts if useful.  Thanks.
5 Replies 5
Reza Sharifi
Ganesh Hariharan
Hello guys,
Cisco 2960 switches can be used with Access point connectivity .Check out the below link for more information
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_sed/configuration/guide/sw8021x.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Leo Laohoo
Addendum:
You need the 2950SX-48 because the 24-port will only support 10/100BaseFx.
And thanks for the ratings.
nsengupta
Any switch with 1G Fiber / Copper will do. Please do not forget to take GLC- (T/SX/LH) to connect the same to the Switch. If on Fiber, please do consider the fiber module as well at the switch end.
