No Opérational VLANs on GE12
ewok2
Bonjour
Sur mon switch CISCO SG250-18 je peux configurer tous les port avec un VLAN particulier (Trunk ou Access) sauf le port 12?
 Comme le montre l'image ci dessus je ne reussi pas a avoir un 40U dans l'Operational VLAN
Une idee ?
Merci
Ok perform with web interface : Status & Statistic / SPAN
remove source and destination
And the port works !!!!
balaji.bandi
edit that port and post the complete screenshot.
BB
ewok2
Hello, thanks for help
Below a screenshot in the port managment / Setting for GE12 that seem's stange and GE13 that works
They seem's identical ?
ewok2
I think I found something interesant.
When login on switch with ssh and launching command "show monitor session 1"
I get :
Session 1:
Type: SPAN
Destination: gi12,
Source: port gi17, both
But I can't remove it
I try a "no monitor session all" but get a "Incomplete command"
