no-payload with dynamic ip
apant12345
Hello.
I have an adsl connection with dynamic ip and nat. I want to access a DNS server in private network (behind nat). I forward ports like
ip nat inside static tcp x.x.x.x 53 interface dialer 0 53
ip nat inside static udp x.x.x.x 53 interface dialer 0 53
but dns queries time out.
It works correctly if I use
ip nat inside static tcp x.x.x.x 53 y.y.y.y 53 extendable no-payload
but y.y.y.y is dynamic so I cannot use it because it often changes. I also cannot use no-payload with "interface dialer 0" instead of y.y.y.y
Is there any solution?
0 Replies 0
