No PPP Multilink on Packet Tracer?
Corey Piazza
I'm trying to follow along on a PPP lab where I have to set up multilink between two serial connections. Having little $ to work with, I only have packet tracer. I'm noticing "interface ?", on pretty much every router I've tried in the app, only gives me:
Dot11Radio Dot11 interface
Ethernet IEEE 802.3
FastEthernet FastEthernet IEEE 802.3
GigabitEthernet GigabitEthernet IEEE 802.3z
Loopback Loopback interface
Port-channel Ethernet Channel of interfaces
Serial Serial
Tunnel Tunnel interface
Virtual-Template Virtual Template interface
Vlan Catalyst Vlans
range interface range command
No multilink...
Is there a lot Packet Tracer doesn't have that the real devices do have?
Thank you,
Corey
Corey,
no multilink indeed in Packet Tracer. Take a look at GNS3, it works with full Cisco IOS images, and it is free as well.
https://www.gns3.com/
I have the same question.
Any idea of what model of Cisco routers support PPP Multilink? Just want to make sure I get the correct image.
Josh
Hi Corey,
Indeed, I have tested it that PPP multilink works on C2691, C3600 and C7200 GNS3 ios image.
