Showing results forĀ
Search instead forĀ
Did you mean:Ā
no shut down error on port (Port fails POST in loopback test)
muhammadusman77
switch cisco 2960
error come when i reboot the switch or when no shut the port
"Port fails POST in loopback test"
can any body explain what that mean.
is there any hardware fault?
any suggestion will be highly appreciated
InayathUlla Sharieff
Yes there could be issue with the hardware.
Could you post the output of show post?
you are right it was a hardware fault. thanks
